[GeoNode-devel] Uploading layer hangs at: Performing Final GeoServer Config Step
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jun 24 10:00:49 PDT 2016
Yeah my suggestion at this point would be to go for the 2.4 stable release,
either with apt-get install on a fresh machine or git clone from the branch
2.4.x
2016-06-24 18:57 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
> yes it is happening both in production and dev modes.
> I am using version 2.4.dev20160527174840 which I obtained by doing a git
> clone of 2.4.x branch.
> May Yahweh bless you and keep you.
> May Yahweh let his face shine on you and be gracious to you.
> May Yahweh show you his face and bring you peace.
> (New Jerusalem Bible Numbers 6:24-26)
> email: marcathian at gmail.com
> Home: 453-3632 / 453-3454
> Mobile: 719-2248
> Work: 468-4434
> On Fri, Jun 24, 2016 at 12:46 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hm, and this is happening both in dev mode and production?
>> btw have you considered using the official release of geonode 2.4?
>> 2016-06-24 17:54 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>> Thanks again Simone.
>>> I have corrected the entry in the geoserver data
>>> dir/security/auth/geonodeAuthProvider/config.xml; and the geoserver now
>>> keeps the login from geonode.
>>> However; the upload still hangs in the same place as initially reported.
>>> What has also been happening is that the data makes its way into
>>> geoserver and is visible from geoserver as a layer. but it will not be
>>> visible in geonode until the update layers command is run and then the
>>> output of the command will say that the layer has been created. at that
>>> point the layer is visible in geonode.
>>> Mobile: 719-2248
>>> Work: 468-4434
>>> On Fri, Jun 24, 2016 at 9:15 AM, Simone Dalmasso <
>>>> You need to tell geoserver where to correctly find geonode. In the
>>>> geoserver data dir/security/auth/geonodeAuthProvider/config.xml you can set
>>>> the correct url of your geonode, then restart tomcat.
>>>> 2016-06-24 15:12 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>>>> Hello Simone;
>>>>> Thanks for your assistance so far.
>>>>> The login from geonode is not kept when the /geoserver is accessed.
>>>>> I have to login again to the geoserver.
>>>>> How do I resolve this?
>>>>> Mobile: 719-2248
>>>>> Work: 468-4434
>>>>> On Fri, Jun 24, 2016 at 7:31 AM, Simone Dalmasso <
>>>>>> Than is not that the issue. Other thing it could be is a
>>>>>> communication issue between geonode and geoserver which could lead to "no
>>>>>> such layer". Does geoserver correctly keeps the login from geonode when you
>>>>>> access "/geoserver" or "localhost:8080/geoserver"?
>>>>>> 2016-06-24 12:07 GMT+02:00 Marcathian Alexander <marcathian at gmail.com
>>>>>>> It is being done in a VM with 4 cores, and 8Gig of RAM.
>>>>>>> the Xms and Xmx values for tomcat are 4096m.
>>>>>>> How may i provide the aditional resources to geoserver?
>>>>>>> Mobile: 719-2248
>>>>>>> Work: 468-4434
>>>>>>> On Fri, Jun 24, 2016 at 3:27 AM, Simone Dalmasso <
>>>>>>>> Hi, could it be that your machine is not powerful enough? Seems
>>>>>>>> that geoserver has not enough resources to process the layer in reasonable
>>>>>>>> time.
>>>>>>>> 2016-06-24 2:18 GMT+02:00 Marcathian Alexander <
>>>>>>>>> Hello;
>>>>>>>>> I am preparing to deploy a geonode installation using GeoNode
>>>>>>>>> version 2.4.dev20160527174840.
>>>>>>>>> When attempting to upload an esri shp file through the upload
>>>>>>>>> layers page the process hangs at the message: performing Final GeoServer
>>>>>>>>> Config Step.
>>>>>>>>> I shall be grateful for assistance in resolving the issue. The
>>>>>>>>> content of the logs are below.
>>>>>>>>> output from the postgresql log:
>>>>>>>>> 2016-06-23 18:44:40 AST [5406-25] geonode at geonode WARNING:
>>>>>>>>> 01000: ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
>>>>>>>>> 2016-06-23 18:44:40 AST [5406-26] geonode at geonode CONTEXT: SQL
>>>>>>>>> function "st_force_2d" during startup
>>>>>>>>> 2016-06-23 18:44:40 AST [5406-27] geonode at geonode LOCATION:
>>>>>>>>> exec_stmt_raise, pl_exec.c:3216
>>>>>>>>> 2016-06-23 18:44:40 AST [5406-28] geonode at geonode STATEMENT:
>>>>>>>>> SELECT
>>>>>>>>> ST_AsText(ST_Force_2D(ST_Envelope(ST_Extent("the_geom"::geometry)))) FROM
>>>>>>>>> "public"."West_Highway"
>>>>>>>>> 2016-06-23 18:44:46 AST [5406-29] geonode at geonode WARNING:
>>>>>>>>> 2016-06-23 18:44:46 AST [5406-30] geonode at geonode CONTEXT: SQL
>>>>>>>>> 2016-06-23 18:44:46 AST [5406-31] geonode at geonode LOCATION:
>>>>>>>>> 2016-06-23 18:44:46 AST [5406-32] geonode at geonode STATEMENT:
>>>>>>>>> SELECT "fid",encode(ST_AsBinary(ST_Force_2D("the_geom")),'base64') as
>>>>>>>>> "the_geom" FROM "public"."West_Highway" WHERE "the_geom" &&
>>>>>>>>> ST_GeomFromText('POLYGON ((487266.2853154304 1518248.9631568347,
>>>>>>>>> 487266.2853154304 1546225.3912784152, 524325.9693206407 1546225.3912784152,
>>>>>>>>> 524325.9693206407 1518248.9631568347, 487266.2853154304
>>>>>>>>> 1518248.9631568347))', 2006) AND ST_Intersects("the_geom",
>>>>>>>>> 1518248.9631568347))', 2006))
>>>>>>>>> Output from TomCat7 log:
>>>>>>>>> Jun 23, 2016 6:44:40 PM org.geoserver.importer.rest.TaskResource
>>>>>>>>> handlePost
>>>>>>>>> INFO: Handling POST of multipart/form-data;
>>>>>>>>> boundary=----------ThIs_Is_tHe_bouNdaRY_$
>>>>>>>>> 23 Jun 18:44:40 WARN [geoserver.security] - Could not find factory
>>>>>>>>> for store : DataStoreInfoImpl[datastore]. Unable to encrypt connection
>>>>>>>>> parameters.
>>>>>>>>> 23 Jun 18:44:40 INFO [org.geoserver] - Loaded store 'datastore',
>>>>>>>>> enabled
>>>>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - begining import
>>>>>>>>> 23 Jun 18:44:40 ERROR [geoserver.rest] - No such layer:
>>>>>>>>> West_Highway
>>>>>>>>> org.geoserver.rest.RestletException
>>>>>>>>> at
>>>>>>>>> org.geoserver.catalog.rest.LayerFinder.findTarget(LayerFinder.java:39)
>>>>>>>>> at org.restlet.Finder.handle(Finder.java:268)
>>>>>>>>> at
>>>>>>>>> org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
>>>>>>>>> at org.restlet.Filter.doHandle(Filter.java:105)
>>>>>>>>> at org.restlet.Filter.handle(Filter.java:134)
>>>>>>>>> at org.restlet.Router.handle(Router.java:444)
>>>>>>>>> at
>>>>>>>>> org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
>>>>>>>>> at
>>>>>>>>> com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
>>>>>>>>> at
>>>>>>>>> org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
>>>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
>>>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
>>>>>>>>> at
>>>>>>>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:111)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>>>>>>> at
>>>>>>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>>>>>>> at
>>>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>>>>>>> at
>>>>>>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>>>>>>> at
>>>>>>>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>>>>>>> at
>>>>>>>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>>>>>>> at
>>>>>>>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>>>>>>> at
>>>>>>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>>>>>>> at
>>>>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>>>>>>> at java.lang.Thread.run(Thread.java:745)
>>>>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - load to target took 104
>>>>>>>>> 23 Jun 18:44:45 INFO [org.geoserver] - Loaded feature type 'null',
>>>>>>>>> enabled
>>>>>>>>> 23 Jun 18:44:45 WARN [catalog.impl] - Failed to load actual store
>>>>>>>>> for FeatureTypeInfoImpl[null]
>>>>>>>>> 23 Jun 18:44:45 INFO [catalog.rest] - PUT
>>>>>>>>> FeatureTypedatastore,West_Highway updated metadata only
>>>>>>>>> 23 Jun 18:44:46 INFO [geoserver.wms] -
>>>>>>>>> Request: getServiceInfo
>>>>>>>>> Request: reflect
>>>>>>>>> SldBody = null
>>>>>>>>> ValidateSchema = false
>>>>>>>>> Sld = null
>>>>>>>>> StyleUrl = null
>>>>>>>>> Width = 200
>>>>>>>>> Height = 150
>>>>>>>>> Interpolations = []
>>>>>>>>> StyleFormat = sld
>>>>>>>>> Transparent = false
>>>>>>>>> TilesOrigin = null
>>>>>>>>> Tiled = false
>>>>>>>>> Palette = null
>>>>>>>>> FeatureVersion = null
>>>>>>>>> SRS = null
>>>>>>>>> Styles = [StyleImpl[ name=geonode_West_Highway1]]
>>>>>>>>> Layers = [org.geoserver.wms.MapLayerInfo at 1ee3d97d]
>>>>>>>>> MaxFeatures = null
>>>>>>>>> Crs = null
>>>>>>>>> Bbox = null
>>>>>>>>> RemoteOwsType = null
>>>>>>>>> RemoteOwsURL = null
>>>>>>>>> Env = {}
>>>>>>>>> FormatOptions = {}
>>>>>>>>> Angle = 0.0
>>>>>>>>> CQLFilter = null
>>>>>>>>> Elevation = []
>>>>>>>>> FeatureId = null
>>>>>>>>> StartIndex = null
>>>>>>>>> ViewParams = null
>>>>>>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>>>>>>> Exceptions = SE_XML
>>>>>>>>> StyleBody = null
>>>>>>>>> SldVersion = null
>>>>>>>>> StyleVersion = null
>>>>>>>>> ScaleMethod = null
>>>>>>>>> Format = image/png8
>>>>>>>>> Buffer = 0
>>>>>>>>> Time = []
>>>>>>>>> Filter = null
>>>>>>>>> Filters = null
>>>>>>>>> Get = true
>>>>>>>>> BaseUrl = http://sling.gosl.gov.lc:8080/geoserver/
>>>>>>>>> RawKvp = {FORMAT=image/png8, HEIGHT=150,
>>>>>>>>> LAYERS=geonode:West_Highway, WIDTH=200}
>>>>>>>>> RequestCharset = UTF-8
>>>>>>>>> Version = null
>>>>>>>>> Request = GetMap
>>>>>>>>> Mobile: 719-2248
>>>>>>>>> Work: 468-4434
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160624/257cba7b/attachment-0001.html>
More information about the geonode-devel
