[GeoNode-devel] Uploading layer hangs at: Performing Final GeoServer Config Step
Marcathian Alexander
marcathian at gmail.com
Fri Jun 24 10:40:12 PDT 2016
I will do that.
May Yahweh bless you and keep you.
May Yahweh let his face shine on you and be gracious to you.
May Yahweh show you his face and bring you peace.
(New Jerusalem Bible Numbers 6:24-26)
email: marcathian at gmail.com
Home: 453-3632 / 453-3454
Mobile: 719-2248
Work: 468-4434
On Fri, Jun 24, 2016 at 1:00 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Yeah my suggestion at this point would be to go for the 2.4 stable
> release, either with apt-get install on a fresh machine or git clone from
> the branch 2.4.x
> 2016-06-24 18:57 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>> yes it is happening both in production and dev modes.
>> I am using version 2.4.dev20160527174840 which I obtained by doing a git
>> clone of 2.4.x branch.
>> Mobile: 719-2248
>> Work: 468-4434
>> On Fri, Jun 24, 2016 at 12:46 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hm, and this is happening both in dev mode and production?
>>> btw have you considered using the official release of geonode 2.4?
>>> 2016-06-24 17:54 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>>> Thanks again Simone.
>>>> I have corrected the entry in the geoserver data
>>>> dir/security/auth/geonodeAuthProvider/config.xml; and the geoserver now
>>>> keeps the login from geonode.
>>>> However; the upload still hangs in the same place as initially
>>>> reported.
>>>> What has also been happening is that the data makes its way into
>>>> geoserver and is visible from geoserver as a layer. but it will not be
>>>> visible in geonode until the update layers command is run and then the
>>>> output of the command will say that the layer has been created. at that
>>>> point the layer is visible in geonode.
>>>> Mobile: 719-2248
>>>> Work: 468-4434
>>>> On Fri, Jun 24, 2016 at 9:15 AM, Simone Dalmasso <
>>>>> You need to tell geoserver where to correctly find geonode. In the
>>>>> geoserver data dir/security/auth/geonodeAuthProvider/config.xml you can set
>>>>> the correct url of your geonode, then restart tomcat.
>>>>> 2016-06-24 15:12 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>
>>>>>> Hello Simone;
>>>>>> Thanks for your assistance so far.
>>>>>> The login from geonode is not kept when the /geoserver is accessed.
>>>>>> I have to login again to the geoserver.
>>>>>> How do I resolve this?
>>>>>> Mobile: 719-2248
>>>>>> Work: 468-4434
>>>>>> On Fri, Jun 24, 2016 at 7:31 AM, Simone Dalmasso <
>>>>>>> Than is not that the issue. Other thing it could be is a
>>>>>>> communication issue between geonode and geoserver which could lead to "no
>>>>>>> such layer". Does geoserver correctly keeps the login from geonode when you
>>>>>>> access "/geoserver" or "localhost:8080/geoserver"?
>>>>>>> 2016-06-24 12:07 GMT+02:00 Marcathian Alexander <
>>>>>>>> It is being done in a VM with 4 cores, and 8Gig of RAM.
>>>>>>>> the Xms and Xmx values for tomcat are 4096m.
>>>>>>>> How may i provide the aditional resources to geoserver?
>>>>>>>> Mobile: 719-2248
>>>>>>>> Work: 468-4434
>>>>>>>> On Fri, Jun 24, 2016 at 3:27 AM, Simone Dalmasso <
>>>>>>>>> Hi, could it be that your machine is not powerful enough? Seems
>>>>>>>>> that geoserver has not enough resources to process the layer in reasonable
>>>>>>>>> time.
>>>>>>>>> 2016-06-24 2:18 GMT+02:00 Marcathian Alexander <
>>>>>>>>>> Hello;
>>>>>>>>>> I am preparing to deploy a geonode installation using GeoNode
>>>>>>>>>> version 2.4.dev20160527174840.
>>>>>>>>>> When attempting to upload an esri shp file through the upload
>>>>>>>>>> layers page the process hangs at the message: performing Final GeoServer
>>>>>>>>>> Config Step.
>>>>>>>>>> I shall be grateful for assistance in resolving the issue. The
>>>>>>>>>> content of the logs are below.
>>>>>>>>>> output from the postgresql log:
>>>>>>>>>> 2016-06-23 18:44:40 AST [5406-25] geonode at geonode WARNING:
>>>>>>>>>> 01000: ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
>>>>>>>>>> 2016-06-23 18:44:40 AST [5406-26] geonode at geonode CONTEXT: SQL
>>>>>>>>>> function "st_force_2d" during startup
>>>>>>>>>> 2016-06-23 18:44:40 AST [5406-27] geonode at geonode LOCATION:
>>>>>>>>>> exec_stmt_raise, pl_exec.c:3216
>>>>>>>>>> 2016-06-23 18:44:40 AST [5406-28] geonode at geonode STATEMENT:
>>>>>>>>>> SELECT
>>>>>>>>>> ST_AsText(ST_Force_2D(ST_Envelope(ST_Extent("the_geom"::geometry)))) FROM
>>>>>>>>>> "public"."West_Highway"
>>>>>>>>>> 2016-06-23 18:44:46 AST [5406-29] geonode at geonode WARNING:
>>>>>>>>>> 2016-06-23 18:44:46 AST [5406-30] geonode at geonode CONTEXT: SQL
>>>>>>>>>> 2016-06-23 18:44:46 AST [5406-31] geonode at geonode LOCATION:
>>>>>>>>>> 2016-06-23 18:44:46 AST [5406-32] geonode at geonode STATEMENT:
>>>>>>>>>> SELECT "fid",encode(ST_AsBinary(ST_Force_2D("the_geom")),'base64') as
>>>>>>>>>> "the_geom" FROM "public"."West_Highway" WHERE "the_geom" &&
>>>>>>>>>> ST_GeomFromText('POLYGON ((487266.2853154304 1518248.9631568347,
>>>>>>>>>> 487266.2853154304 1546225.3912784152, 524325.9693206407 1546225.3912784152,
>>>>>>>>>> 524325.9693206407 1518248.9631568347, 487266.2853154304
>>>>>>>>>> 1518248.9631568347))', 2006) AND ST_Intersects("the_geom",
>>>>>>>>>> 1518248.9631568347))', 2006))
>>>>>>>>>> Output from TomCat7 log:
>>>>>>>>>> Jun 23, 2016 6:44:40 PM org.geoserver.importer.rest.TaskResource
>>>>>>>>>> handlePost
>>>>>>>>>> INFO: Handling POST of multipart/form-data;
>>>>>>>>>> boundary=----------ThIs_Is_tHe_bouNdaRY_$
>>>>>>>>>> 23 Jun 18:44:40 WARN [geoserver.security] - Could not find
>>>>>>>>>> factory for store : DataStoreInfoImpl[datastore]. Unable to encrypt
>>>>>>>>>> connection parameters.
>>>>>>>>>> 23 Jun 18:44:40 INFO [org.geoserver] - Loaded store 'datastore',
>>>>>>>>>> enabled
>>>>>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - begining import
>>>>>>>>>> 23 Jun 18:44:40 ERROR [geoserver.rest] - No such layer:
>>>>>>>>>> West_Highway
>>>>>>>>>> org.geoserver.rest.RestletException
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.catalog.rest.LayerFinder.findTarget(LayerFinder.java:39)
>>>>>>>>>> at org.restlet.Finder.handle(Finder.java:268)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
>>>>>>>>>> at org.restlet.Filter.doHandle(Filter.java:105)
>>>>>>>>>> at org.restlet.Filter.handle(Filter.java:134)
>>>>>>>>>> at org.restlet.Router.handle(Router.java:444)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
>>>>>>>>>> at
>>>>>>>>>> com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
>>>>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
>>>>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:111)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>>>>>>>> at
>>>>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>>>>>>>> at
>>>>>>>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>>>>>>>> at
>>>>>>>>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>>>>>>>> at
>>>>>>>>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>>>>>>>> at
>>>>>>>>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>>>>>>>> at
>>>>>>>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>>>>>>>> at
>>>>>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>>>>>>>> at java.lang.Thread.run(Thread.java:745)
>>>>>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - load to target took
>>>>>>>>>> 104
>>>>>>>>>> 23 Jun 18:44:45 INFO [org.geoserver] - Loaded feature type
>>>>>>>>>> 'null', enabled
>>>>>>>>>> 23 Jun 18:44:45 WARN [catalog.impl] - Failed to load actual store
>>>>>>>>>> for FeatureTypeInfoImpl[null]
>>>>>>>>>> 23 Jun 18:44:45 INFO [catalog.rest] - PUT
>>>>>>>>>> FeatureTypedatastore,West_Highway updated metadata only
>>>>>>>>>> 23 Jun 18:44:46 INFO [geoserver.wms] -
>>>>>>>>>> Request: getServiceInfo
>>>>>>>>>> Request: reflect
>>>>>>>>>> SldBody = null
>>>>>>>>>> ValidateSchema = false
>>>>>>>>>> Sld = null
>>>>>>>>>> StyleUrl = null
>>>>>>>>>> Width = 200
>>>>>>>>>> Height = 150
>>>>>>>>>> Interpolations = []
>>>>>>>>>> StyleFormat = sld
>>>>>>>>>> Transparent = false
>>>>>>>>>> TilesOrigin = null
>>>>>>>>>> Tiled = false
>>>>>>>>>> Palette = null
>>>>>>>>>> FeatureVersion = null
>>>>>>>>>> SRS = null
>>>>>>>>>> Styles = [StyleImpl[ name=geonode_West_Highway1]]
>>>>>>>>>> Layers = [org.geoserver.wms.MapLayerInfo at 1ee3d97d]
>>>>>>>>>> MaxFeatures = null
>>>>>>>>>> Crs = null
>>>>>>>>>> Bbox = null
>>>>>>>>>> RemoteOwsType = null
>>>>>>>>>> RemoteOwsURL = null
>>>>>>>>>> Env = {}
>>>>>>>>>> FormatOptions = {}
>>>>>>>>>> Angle = 0.0
>>>>>>>>>> CQLFilter = null
>>>>>>>>>> Elevation = []
>>>>>>>>>> FeatureId = null
>>>>>>>>>> StartIndex = null
>>>>>>>>>> ViewParams = null
>>>>>>>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>>>>>>>> Exceptions = SE_XML
>>>>>>>>>> StyleBody = null
>>>>>>>>>> SldVersion = null
>>>>>>>>>> StyleVersion = null
>>>>>>>>>> ScaleMethod = null
>>>>>>>>>> Format = image/png8
>>>>>>>>>> Buffer = 0
>>>>>>>>>> Time = []
>>>>>>>>>> Filter = null
>>>>>>>>>> Filters = null
>>>>>>>>>> Get = true
>>>>>>>>>> BaseUrl = http://sling.gosl.gov.lc:8080/geoserver/
>>>>>>>>>> RawKvp = {FORMAT=image/png8, HEIGHT=150,
>>>>>>>>>> LAYERS=geonode:West_Highway, WIDTH=200}
>>>>>>>>>> RequestCharset = UTF-8
>>>>>>>>>> Version = null
>>>>>>>>>> Request = GetMap
>>>>>>>>>> Mobile: 719-2248
>>>>>>>>>> Work: 468-4434
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160624/4d133246/attachment-0001.html>
More information about the geonode-devel
