[GeoNode-devel] Unable to install GeoNode on a fresh Ubuntu
Paolo Pasquali
paolo.pasquali at gmail.com
Mon Mar 21 06:43:08 PDT 2016
Yes, I did apt-get update.
...and well, the machine is an AWS t2.micro so it could be a performance
issue.
Thanks, Simo.
I'll try with another instance.
Ciao
P.
On Mon, Mar 21, 2016 at 2:33 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Paolo,
> did u run apt-get update before right?
> Are the machine performances high enough?
> 2016-03-21 12:50 GMT+01:00 Paolo Pasquali <paolo.pasquali at gmail.com>:
>> Hi devs,
>> I'm getting an error on a fresh Ubuntu 14.04 while trying to install a
>> system wide GeoNode.
>> So after sudo apt-get install geonode I get this:
>> Setting up geoserver-geonode (2.7.4-2) ...
>> * Stopping Tomcat servlet engine tomcat7
>> [ OK ]
>> * Starting Tomcat servlet engine tomcat7
>> [fail]
>> dpkg: error processing package geoserver-geonode (--configure):
>> subprocess installed post-installation script returned error exit status
>> 1
>> Setting up python-multipartposthandler (0.1.0-2) ...
>> dpkg: dependency problems prevent configuration of geonode:
>> geonode depends on geoserver-geonode | geoserver; however:
>> Package geoserver-geonode is not configured yet.
>> Package geoserver is not installed.
>> dpkg: error processing package geonode (--configure):
>> dependency problems - leaving unconfigured
>> No apport report written because the error message indicates its a
>> followup error from a previous failure.
>> Processing triggers for libc-bin
>> (2.19-0ubuntu6.7) ...
>> Processing triggers for python-support (1.0.15) ...
>> Errors were encountered while processing:
>> geoserver-geonode
>> geonode
>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>> Thanks for your help.
>> Best,
>> Paolo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160321/62950e7c/attachment.html>
More information about the geonode-devel
