[GeoNode-devel] Unable to install GeoNode on a fresh Ubuntu
Simone Dalmasso simone.dalmasso at gmail.com
Mon Mar 21 06:43:54 PDT 2016
yep, micro no good. no no good :)
2016-03-21 14:43 GMT+01:00 Paolo Pasquali <paolo.pasquali at gmail.com>:
> Yes, I did apt-get update.
> ...and well, the machine is an AWS t2.micro so it could be a performance
> issue.
> Thanks, Simo.
> I'll try with another instance.
> Ciao
> P.
> On Mon, Mar 21, 2016 at 2:33 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi Paolo,
>> did u run apt-get update before right?
>> Are the machine performances high enough?
>> 2016-03-21 12:50 GMT+01:00 Paolo Pasquali <paolo.pasquali at gmail.com>:
>>> Hi devs,
>>> I'm getting an error on a fresh Ubuntu 14.04 while trying to install a
>>> system wide GeoNode.
>>> So after sudo apt-get install geonode I get this:
>>> Setting up geoserver-geonode (2.7.4-2) ...
>>>  * Stopping Tomcat servlet engine tomcat7
>>>              [ OK ]
>>>  * Starting Tomcat servlet engine tomcat7
>>>              [fail]
>>> dpkg: error processing package geoserver-geonode (--configure):
>>>  subprocess installed post-installation script returned error exit
>>> status 1
>>> Setting up python-multipartposthandler (0.1.0-2) ...
>>> dpkg: dependency problems prevent configuration of geonode:
>>>  geonode depends on geoserver-geonode | geoserver; however:
>>>   Package geoserver-geonode is not configured yet.
>>>   Package geoserver is not installed.
>>> dpkg: error processing package geonode (--configure):
>>>  dependency problems - leaving unconfigured
>>> No apport report written because the error message indicates its a
>>> followup error from a previous failure.
>>>                                   Processing triggers for libc-bin
>>> (2.19-0ubuntu6.7) ...
>>> Processing triggers for python-support (1.0.15) ...
>>> Errors were encountered while processing:
>>>  geoserver-geonode
>>>  geonode
>>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>>> Thanks for your help.
>>> Best,
>>> Paolo
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160321/f5556064/attachment-0001.html>
More information about the geonode-devel mailing list
