[GeoNode-devel] Setting up Geosites with custom Geonode as master
Simone Dalmasso
simone.dalmasso at gmail.com
Wed May 18 00:59:58 PDT 2016
No you can use your custom geonode, if you customised it by forking the
geonode code then the only quick way would be to use it as a base for all
sites. Otherwise you have to extract the customisations and port them in a
geonode-project that you will use a s a site-specific folder.
2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
> Hi Simone,
> Thank you very much for the prompt response. Do we just put our custom
> Geonode inside this template folder, including the additional apps we
> created? Do we just put our custom Geonode under the master directory so it
> will be used as the master website? Do I still have to install the Geonode
> pip package?
> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi Carlos,
>> you can follow the docs here
>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites.
>> Basically you have to create a folder from this template
>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>> each geosite and assign it to the correct site. There is a command that
>> should help you in creating both the entries in the db and the skeleton of
>> the site folder
>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>> Once you enable geosites, users and resources will belong to the site
>> where they have been created or they have been assigned from the admin
>> panel.
>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>> Hi all,
>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the process of
>>> developing our custom version of Geonode. We're also looking into using
>>> Geosites.
>>> My question is, how do we setup Geosites using our custom Geonode (we
>>> call it LiPAD)? We followed these instructions
>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>> in setting up our custom Geonode. From this point, what steps do we have to
>>> take to utilize Geosites?
>>> Thank you very much.
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/8fb5f36f/attachment.html>
More information about the geonode-devel
