[GeoNode-devel] Setting up Geosites with custom Geonode as	master
    Carlo Santos
    santos.carlo.a at gmail.com
    Wed May 18 00:57:19 PDT 2016
Hi Simone,
Thank you very much for the prompt response. Do we just put our custom
Geonode inside this template folder, including the additional apps we
created? Do we just put our custom Geonode under the master directory so it
will be used as the master website? Do I still have to install the Geonode
pip package?
On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Carlos,
> you can follow the docs here
> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites.
> Basically you have to create a folder from this template
> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
> each geosite and assign it to the correct site. There is a command that
> should help you in creating both the entries in the db and the skeleton of
> the site folder
> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
> Once you enable geosites, users and resources will belong to the site
> where they have been created or they have been assigned from the admin
> panel.
> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>> Hi all,
>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the process of
>> developing our custom version of Geonode. We're also looking into using
>> Geosites.
>> My question is, how do we setup Geosites using our custom Geonode (we
>> call it LiPAD)? We followed these instructions
>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>> in setting up our custom Geonode. From this point, what steps do we have to
>> take to utilize Geosites?
>> Thank you very much.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/e98c0d91/attachment.html>
More information about the geonode-devel
