[GeoNode-devel] Setting up Geosites with custom Geonode as master
Simone Dalmasso
simone.dalmasso at gmail.com
Wed May 18 01:12:47 PDT 2016
it will, you will still issue the commands from the geonode main folder
2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
> Will using paver still work?
> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> No you can use your custom geonode, if you customised it by forking the
>> geonode code then the only quick way would be to use it as a base for all
>> sites. Otherwise you have to extract the customisations and port them in a
>> geonode-project that you will use a s a site-specific folder.
>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>> Hi Simone,
>>> Thank you very much for the prompt response. Do we just put our custom
>>> Geonode inside this template folder, including the additional apps we
>>> created? Do we just put our custom Geonode under the master directory so it
>>> will be used as the master website? Do I still have to install the Geonode
>>> pip package?
>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>> Hi Carlos,
>>>> you can follow the docs here
>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>> Basically you have to create a folder from this template
>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>> each geosite and assign it to the correct site. There is a command that
>>>> should help you in creating both the entries in the db and the skeleton of
>>>> the site folder
>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>> Once you enable geosites, users and resources will belong to the site
>>>> where they have been created or they have been assigned from the admin
>>>> panel.
>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>> Hi all,
>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the process
>>>>> of developing our custom version of Geonode. We're also looking into using
>>>>> Geosites.
>>>>> My question is, how do we setup Geosites using our custom Geonode (we
>>>>> call it LiPAD)? We followed these instructions
>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>> take to utilize Geosites?
>>>>> Thank you very much.
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/8d9c227b/attachment-0001.html>
More information about the geonode-devel
