[GeoNode-devel] Setting up Geosites with custom Geonode as master
Carlo Santos
santos.carlo.a at gmail.com
Wed May 18 01:15:21 PDT 2016
Got it. Thank you very much!
On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> it will, you will still issue the commands from the geonode main folder
> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>> Will using paver still work?
>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> No you can use your custom geonode, if you customised it by forking the
>>> geonode code then the only quick way would be to use it as a base for all
>>> sites. Otherwise you have to extract the customisations and port them in a
>>> geonode-project that you will use a s a site-specific folder.
>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>> Hi Simone,
>>>> Thank you very much for the prompt response. Do we just put our custom
>>>> Geonode inside this template folder, including the additional apps we
>>>> created? Do we just put our custom Geonode under the master directory so it
>>>> will be used as the master website? Do I still have to install the Geonode
>>>> pip package?
>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>> Hi Carlos,
>>>>> you can follow the docs here
>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>> Basically you have to create a folder from this template
>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>> each geosite and assign it to the correct site. There is a command that
>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>> the site folder
>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>> Once you enable geosites, users and resources will belong to the site
>>>>> where they have been created or they have been assigned from the admin
>>>>> panel.
>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>> Hi all,
>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the process
>>>>>> of developing our custom version of Geonode. We're also looking into using
>>>>>> Geosites.
>>>>>> My question is, how do we setup Geosites using our custom Geonode (we
>>>>>> call it LiPAD)? We followed these instructions
>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>> take to utilize Geosites?
>>>>>> Thank you very much.
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/75dea5da/attachment.html>
More information about the geonode-devel
