[GeoNode-devel] Setting up Geosites with custom Geonode as master
Carlo Santos santos.carlo.a at gmail.com
Wed May 18 01:30:35 PDT 2016
Is this an accurate example of the directory setup?
https://github.com/cspanring/geonode/tree/geosites
On Wed, May 18, 2016 at 4:15 PM, Carlo Santos <santos.carlo.a at gmail.com>
wrote:
> Got it. Thank you very much!
> On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> it will, you will still issue the commands from the geonode main folder
>> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>> Will using paver still work?
>>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>>>> No you can use your custom geonode, if you customised it by forking the
>>>> geonode code then the only quick way would be to use it as a base for all
>>>> sites. Otherwise you have to extract the customisations and port them in a
>>>> geonode-project that you will use a s a site-specific folder.
>>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>> Hi Simone,
>>>>> Thank you very much for the prompt response. Do we just put our custom
>>>>> Geonode inside this template folder, including the additional apps we
>>>>> created? Do we just put our custom Geonode under the master directory so it
>>>>> will be used as the master website? Do I still have to install the Geonode
>>>>> pip package?
>>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>>> Hi Carlos,
>>>>>> you can follow the docs here
>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>>> Basically you have to create a folder from this template
>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>>> each geosite and assign it to the correct site. There is a command that
>>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>>> the site folder
>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>>> Once you enable geosites, users and resources will belong to the site
>>>>>> where they have been created or they have been assigned from the admin
>>>>>> panel.
>>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>> Hi all,
>>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the
>>>>>>> process of developing our custom version of Geonode. We're also looking
>>>>>>> into using Geosites.
>>>>>>> My question is, how do we setup Geosites using our custom Geonode
>>>>>>> (we call it LiPAD)? We followed these instructions
>>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>>> take to utilize Geosites?
>>>>>>> Thank you very much.
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> Simone
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/da586198/attachment.html>
More information about the geonode-devel mailing list
