[GeoNode-devel] Setting up Geosites with custom Geonode as master
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 18 01:38:24 PDT 2016
No, that one looks a bit old.
this one is a good example https://github.com/terranodo/landscapeportal
<https://github.com/terranodo/landscapeportal>
2016-05-18 10:30 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
> Is this an accurate example of the directory setup?
> https://github.com/cspanring/geonode/tree/geosites
> On Wed, May 18, 2016 at 4:15 PM, Carlo Santos <santos.carlo.a at gmail.com>
> wrote:
>> Got it. Thank you very much!
>> On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> it will, you will still issue the commands from the geonode main folder
>>> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>> Will using paver still work?
>>>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>>>>> No you can use your custom geonode, if you customised it by forking
>>>>> the geonode code then the only quick way would be to use it as a base for
>>>>> all sites. Otherwise you have to extract the customisations and port them
>>>>> in a geonode-project that you will use a s a site-specific folder.
>>>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>> Hi Simone,
>>>>>> Thank you very much for the prompt response. Do we just put our
>>>>>> custom Geonode inside this template folder, including the additional apps
>>>>>> we created? Do we just put our custom Geonode under the master directory so
>>>>>> it will be used as the master website? Do I still have to install the
>>>>>> Geonode pip package?
>>>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>>>> Hi Carlos,
>>>>>>> you can follow the docs here
>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>>>> Basically you have to create a folder from this template
>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>>>> each geosite and assign it to the correct site. There is a command that
>>>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>>>> the site folder
>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>>>> Once you enable geosites, users and resources will belong to the
>>>>>>> site where they have been created or they have been assigned from the admin
>>>>>>> panel.
>>>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>>> Hi all,
>>>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the
>>>>>>>> process of developing our custom version of Geonode. We're also looking
>>>>>>>> into using Geosites.
>>>>>>>> My question is, how do we setup Geosites using our custom Geonode
>>>>>>>> (we call it LiPAD)? We followed these instructions
>>>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>>>> take to utilize Geosites?
>>>>>>>> Thank you very much.
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> Simone
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/7282a80c/attachment-0001.html>
More information about the geonode-devel mailing list
