[GeoNode-devel] Setting up Geosites with custom Geonode as master
Carlo Santos
santos.carlo.a at gmail.com
Wed May 18 01:41:53 PDT 2016
But where are the other apps, and their corresponding views, models, and
other stuff?
On Wed, May 18, 2016 at 4:38 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> No, that one looks a bit old.
> this one is a good example https://github.com/terranodo/landscapeportal
> <https://github.com/terranodo/landscapeportal>
> 2016-05-18 10:30 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>> Is this an accurate example of the directory setup?
>> https://github.com/cspanring/geonode/tree/geosites
>> On Wed, May 18, 2016 at 4:15 PM, Carlo Santos <santos.carlo.a at gmail.com>
>> wrote:
>>> Got it. Thank you very much!
>>> On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> it will, you will still issue the commands from the geonode main folder
>>>> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>> Will using paver still work?
>>>>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>>>>>> No you can use your custom geonode, if you customised it by forking
>>>>>> the geonode code then the only quick way would be to use it as a base for
>>>>>> all sites. Otherwise you have to extract the customisations and port them
>>>>>> in a geonode-project that you will use a s a site-specific folder.
>>>>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>> Hi Simone,
>>>>>>> Thank you very much for the prompt response. Do we just put our
>>>>>>> custom Geonode inside this template folder, including the additional apps
>>>>>>> we created? Do we just put our custom Geonode under the master directory so
>>>>>>> it will be used as the master website? Do I still have to install the
>>>>>>> Geonode pip package?
>>>>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>>>>> Hi Carlos,
>>>>>>>> you can follow the docs here
>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>>>>> Basically you have to create a folder from this template
>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>>>>> each geosite and assign it to the correct site. There is a command that
>>>>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>>>>> the site folder
>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>>>>> Once you enable geosites, users and resources will belong to the
>>>>>>>> site where they have been created or they have been assigned from the admin
>>>>>>>> panel.
>>>>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>>>> Hi all,
>>>>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the
>>>>>>>>> process of developing our custom version of Geonode. We're also looking
>>>>>>>>> into using Geosites.
>>>>>>>>> My question is, how do we setup Geosites using our custom Geonode
>>>>>>>>> (we call it LiPAD)? We followed these instructions
>>>>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>>>>> take to utilize Geosites?
>>>>>>>>> Thank you very much.
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/87c0db89/attachment.html>
More information about the geonode-devel
