[GeoNode-devel] Setting up Geosites with custom Geonode as master
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 18 01:43:13 PDT 2016
They are in geonode and geonode is installed with pip so it is available to
the downstream sites.
2016-05-18 10:41 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
> But where are the other apps, and their corresponding views, models, and
> other stuff?
> On Wed, May 18, 2016 at 4:38 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> No, that one looks a bit old.
>> this one is a good example https://github.com/terranodo/landscapeportal
>> <https://github.com/terranodo/landscapeportal>
>> 2016-05-18 10:30 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>> Is this an accurate example of the directory setup?
>>> https://github.com/cspanring/geonode/tree/geosites
>>> On Wed, May 18, 2016 at 4:15 PM, Carlo Santos <santos.carlo.a at gmail.com>
>>> wrote:
>>>> Got it. Thank you very much!
>>>> On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <
>>>>> it will, you will still issue the commands from the geonode main folder
>>>>> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>> Will using paver still work?
>>>>>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>>>>>>> No you can use your custom geonode, if you customised it by forking
>>>>>>> the geonode code then the only quick way would be to use it as a base for
>>>>>>> all sites. Otherwise you have to extract the customisations and port them
>>>>>>> in a geonode-project that you will use a s a site-specific folder.
>>>>>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>>> Hi Simone,
>>>>>>>> Thank you very much for the prompt response. Do we just put our
>>>>>>>> custom Geonode inside this template folder, including the additional apps
>>>>>>>> we created? Do we just put our custom Geonode under the master directory so
>>>>>>>> it will be used as the master website? Do I still have to install the
>>>>>>>> Geonode pip package?
>>>>>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>>>>>> Hi Carlos,
>>>>>>>>> you can follow the docs here
>>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>>>>>> Basically you have to create a folder from this template
>>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>>>>>> each geosite and assign it to the correct site. There is a command that
>>>>>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>>>>>> the site folder
>>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>>>>>> Once you enable geosites, users and resources will belong to the
>>>>>>>>> site where they have been created or they have been assigned from the admin
>>>>>>>>> panel.
>>>>>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>>>>> Hi all,
>>>>>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the
>>>>>>>>>> process of developing our custom version of Geonode. We're also looking
>>>>>>>>>> into using Geosites.
>>>>>>>>>> My question is, how do we setup Geosites using our custom Geonode
>>>>>>>>>> (we call it LiPAD)? We followed these instructions
>>>>>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>>>>>> take to utilize Geosites?
>>>>>>>>>> Thank you very much.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/fae42407/attachment-0001.html>
More information about the geonode-devel mailing list
