[GeoNode-devel] Setting up Geosites with custom Geonode as master
Carlo Santos santos.carlo.a at gmail.com
Wed May 18 01:45:27 PDT 2016
So do I just replace/overwrite the installed geonode with our customized
one?
On Wed, May 18, 2016 at 4:43 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> They are in geonode and geonode is installed with pip so it is available
> to the downstream sites.
> 2016-05-18 10:41 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>> But where are the other apps, and their corresponding views, models, and
>> other stuff?
>> On Wed, May 18, 2016 at 4:38 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> No, that one looks a bit old.
>>> this one is a good example https://github.com/terranodo/landscapeportal
>>> <https://github.com/terranodo/landscapeportal>
>>> 2016-05-18 10:30 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>> Is this an accurate example of the directory setup?
>>>> https://github.com/cspanring/geonode/tree/geosites
>>>> On Wed, May 18, 2016 at 4:15 PM, Carlo Santos <santos.carlo.a at gmail.com
>>>> > wrote:
>>>>> Got it. Thank you very much!
>>>>> On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <
>>>>>> it will, you will still issue the commands from the geonode main
>>>>>> folder
>>>>>> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>> Will using paver still work?
>>>>>>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>>>>>>>> No you can use your custom geonode, if you customised it by forking
>>>>>>>> the geonode code then the only quick way would be to use it as a base for
>>>>>>>> all sites. Otherwise you have to extract the customisations and port them
>>>>>>>> in a geonode-project that you will use a s a site-specific folder.
>>>>>>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>>>> Hi Simone,
>>>>>>>>> Thank you very much for the prompt response. Do we just put our
>>>>>>>>> custom Geonode inside this template folder, including the additional apps
>>>>>>>>> we created? Do we just put our custom Geonode under the master directory so
>>>>>>>>> it will be used as the master website? Do I still have to install the
>>>>>>>>> Geonode pip package?
>>>>>>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>>>>>>> Hi Carlos,
>>>>>>>>>> you can follow the docs here
>>>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>>>>>>> Basically you have to create a folder from this template
>>>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>>>>>>> each geosite and assign it to the correct site. There is a command that
>>>>>>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>>>>>>> the site folder
>>>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>>>>>>> Once you enable geosites, users and resources will belong to the
>>>>>>>>>> site where they have been created or they have been assigned from the admin
>>>>>>>>>> panel.
>>>>>>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>
>>>>>>>>>>> Hi all,
>>>>>>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the
>>>>>>>>>>> process of developing our custom version of Geonode. We're also looking
>>>>>>>>>>> into using Geosites.
>>>>>>>>>>> My question is, how do we setup Geosites using our custom
>>>>>>>>>>> Geonode (we call it LiPAD)? We followed these instructions
>>>>>>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>>>>>>> take to utilize Geosites?
>>>>>>>>>>> Thank you very much.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/42e04f7e/attachment.html>
More information about the geonode-devel mailing list
