[GeoNode-devel] Setting up Geosites with custom Geonode as master
Carlo Santos santos.carlo.a at gmail.com
Wed May 18 01:52:55 PDT 2016
Aah I see. That clears up a lot of things. Thank you very much for your
time and your patience.
On Wed, May 18, 2016 at 4:51 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Well, there should be just one geonode. if your customisations are on a
> geonode fork, then the answer is yes. You have to install it systemwide or
> in a virtualenv and then enable it's geosites.
> 2016-05-18 10:45 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>> So do I just replace/overwrite the installed geonode with our customized
>> one?
>> On Wed, May 18, 2016 at 4:43 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> They are in geonode and geonode is installed with pip so it is available
>>> to the downstream sites.
>>> 2016-05-18 10:41 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>> But where are the other apps, and their corresponding views, models,
>>>> and other stuff?
>>>> On Wed, May 18, 2016 at 4:38 PM, Simone Dalmasso <
>>>>> No, that one looks a bit old.
>>>>> this one is a good example
>>>>>  https://github.com/terranodo/landscapeportal
>>>>> <https://github.com/terranodo/landscapeportal>
>>>>> 2016-05-18 10:30 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>> Is this an accurate example of the directory setup?
>>>>>> https://github.com/cspanring/geonode/tree/geosites
>>>>>> On Wed, May 18, 2016 at 4:15 PM, Carlo Santos <
>>>>>> santos.carlo.a at gmail.com> wrote:
>>>>>>> Got it. Thank you very much!
>>>>>>> On Wed, May 18, 2016 at 4:12 PM, Simone Dalmasso <
>>>>>>>> it will, you will still issue the commands from the geonode main
>>>>>>>> folder
>>>>>>>> 2016-05-18 10:09 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>>>>>>> Will using paver still work?
>>>>>>>>> On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <
>>>>>>>>>> No you can use your custom geonode, if you customised it by
>>>>>>>>>> forking the geonode code then the only quick way would be to use it as a
>>>>>>>>>> base for all sites. Otherwise you have to extract the customisations and
>>>>>>>>>> port them in a geonode-project that you will use a s a site-specific folder.
>>>>>>>>>> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>
>>>>>>>>>>> Hi Simone,
>>>>>>>>>>> Thank you very much for the prompt response. Do we just put our
>>>>>>>>>>> custom Geonode inside this template folder, including the additional apps
>>>>>>>>>>> we created? Do we just put our custom Geonode under the master directory so
>>>>>>>>>>> it will be used as the master website? Do I still have to install the
>>>>>>>>>>> Geonode pip package?
>>>>>>>>>>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>>>>>>>>>>>> Hi Carlos,
>>>>>>>>>>>> you can follow the docs here
>>>>>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
>>>>>>>>>>>> Basically you have to create a folder from this template
>>>>>>>>>>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>>>>>>>>>>> each geosite and assign it to the correct site. There is a command that
>>>>>>>>>>>> should help you in creating both the entries in the db and the skeleton of
>>>>>>>>>>>> the site folder
>>>>>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>>>>>>>>>>> Once you enable geosites, users and resources will belong to
>>>>>>>>>>>> the site where they have been created or they have been assigned from the
>>>>>>>>>>>> admin panel.
>>>>>>>>>>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <
>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the
>>>>>>>>>>>>> process of developing our custom version of Geonode. We're also looking
>>>>>>>>>>>>> into using Geosites.
>>>>>>>>>>>>> My question is, how do we setup Geosites using our custom
>>>>>>>>>>>>> Geonode (we call it LiPAD)? We followed these instructions
>>>>>>>>>>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>>>>>>>>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>>>>>>>>>>> take to utilize Geosites?
>>>>>>>>>>>>> Thank you very much.
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/26ae55f6/attachment.html>
More information about the geonode-devel mailing list
