[GeoNode-devel] QueryBuilder for Download Layer functionality
Jeffrey Johnson
ortelius at gmail.com
Mon May 23 08:28:00 PDT 2016
This looks great. Can you guys put together a GNIP + PR ?
On Mon, May 23, 2016 at 8:14 AM, Dimitris Karakostis
<karakostis.dimitris at gmail.com> wrote:
> Hi guys,
> I have deployed the newly developed 'Query Builder and Map Filter' tool in
> our staging server for WFP Geonode: http://staging.geonode.wfp.org/layers/
> There are still several features to be added but you can have a look and
> give some recommendations, improvement ideas etc.
> To use the tool, select a layer, click the Download button and then the
> Layer Filtering.
> Cheers
> Dimitris
> On Mon, May 16, 2016 at 9:09 PM, Patrick Dufour <pjdufour.dev at gmail.com>
> wrote:
>> Yes, I can help with the GNIP when ready.
>> The implementation will leverage the cql_filter GeoServer WFS querystring
>> parameter, as such no changes to GeoServer or django DB models are needed.
>> Regards,
>> Patrick Dufour
>> On May 16, 2016 6:11 PM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
>>> This is really awesome!
>>> Can you file a GNIP for this so we can discuss the implementation as a
>>> group? If you need help with that, let us know. You will need a core
>>> committer to actually file the GNIP. Perhaps Patrick can help?
>>> Looking forward to seeing/using this!
>>> Jeff
>>> On Mon, May 16, 2016 at 2:34 AM, Dimitris Karakostis
>>> > Hello guys,
>>> > How are you doing? I wanted to share with you our current development
>>> > plans/progress for WFPGeonode. During the last week I have been working
>>> > on
>>> > the implementation of a 'Query Builder' functionality in order to be
>>> > able to
>>> > download specific parts of layers in the provided formats (kml, xls,
>>> > csv,
>>> > zipped shape, geojson).
>>> > The user can build the query by :
>>> > 1. selecting from a dropdown menu the available attributes,
>>> > 2. selecting an operator,
>>> > 3. enter a valid value
>>> > The different statements of the query can be combined either with AND
>>> > or OR
>>> > operator. I have also used the OWSLib (0.11.0; thanks Tom) in order to
>>> > get
>>> > the type of attributes and apply some sort of validation (e.g. if you
>>> > try to
>>> > put a string, while number is expected then you get an error message).
>>> > For the above process I have used JQuery for the JS functionality and
>>> > BootstrapCSS for the gui. The tool is part of the 'Download Layer'
>>> > modal and
>>> > is currently being tested and making small fixes.
>>> > The next step will be to build a map tool, which you will select the
>>> > area of
>>> > interest (rectangle tool; bounding box etc.) and download it.
>>> > I attach some screenshots of the two tools. If you have any
>>> > ideas/advice/comments please let me know. They are most welcome!
>>> > Cheers
>>> > Dimitris
>>> > _______________________________________________
>>> > geonode-devel mailing list
>>> > geonode-devel at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel
