[GeoNode-devel] Supervisor + Gunicorn
Daniel Berry
dberry at boundlessgeo.com
Tue May 31 09:40:30 PDT 2016
Patrick,
I have setup supervisor + gunicorn + tomcat in a centos instance. I have
seen some delays, but I am in the process of including memcached...
hopefully that will help. Apache is being used as the reverse proxy for
gunicorn(HTTP:8000) and tomcat (AJP:8009).
You could also have uwsgi running as a subprocess under supervisord.
GeoSHAPE uses supervisord for celery and uwsgi processes.
https://github.com/ROGUE-JCTD/rpmbuild/blob/master/SOURCES/supervisord.conf
Dan
On Tue, May 31, 2016 at 10:54 AM, Patrick Dufour <pjdufour.dev at gmail.com>
wrote:
> All,
> Has anyone used supervisor and gunicorn for a GeoNode instance or a
> cluster of instances before?
> An instance I help manage currently uses system managed uwsgi/GeoNode and
> tomcat/GeoServer processes.
> I was thinking of switching to supervisor to manage the gunicorn and
> tomcat processes, so the configuration could be managed in a
> supervisord.conf file and supervisorctl at the project roots instead of
> config spread across system /etc files. Supervisor can also be accessed
> through a python virtual environment rather than system python. I think it
> might help with maintainability.
> I saw some online blog posts saying Gunicorn is slow, but is the
> performance speed so bad it negates benefits of visibility.
> Relevant lessons learned would be appreciated.
> Thanks very much.
> Patrick
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
*Daniel Berry*
Senior Software Engineer | Boundless
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160531/5a45bed9/attachment.html>
More information about the geonode-devel
