[GeoNode-devel] GeoServer version 2.8.x+ ?
Jeffrey Johnson
ortelius at gmail.com
Tue May 31 10:44:05 PDT 2016
+1 from me
On Tue, May 31, 2016 at 5:25 AM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Ciao Alessio,
> +1 for me.
> Thanks
> 2016-05-31 10:08 GMT+02:00 Alessio Fabiani
> <alessio.fabiani at geo-solutions.it>:
>> Dear all,
>> while the Backup & Restore stuff for GeoServer is moving towards the end
>> of development
>> (https://github.com/geosolutions-it/geoserver/tree/backup_restore)
>> I would like to propose here an update of the GeoServer version on GeoNode
>> master branch too.
>> GeoServer is currently at version 2.10 while GeoNode is still using the
>> old 2.7 one.
>> Consider also that in few days we plan to start working on an heavy
>> refactoring of the Authorization & Authentication subsystem of
>> GeoNode/GeoServer.
>> The new GeoServer versions not only have a lot of new features but also
>> bug-fixes, performance improvements and some heavy refactoring of the code
>> base which allows GeoServer to work much better and be quite versatile.
>> I guess we should start thinking to move at least at version 2.8.x of
>> GeoServer if not a newest one.
>> I volunteer to update the security plugins if the community agrees on the
>> version update.
>> Please let me know what are your thoughts about this topic.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>> finalità diverse, costituisce comportamento contrario ai principi dettati
>> dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender does
>> not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
More information about the geonode-devel
