[GeoNode-devel] GeoServer version 2.8.x+ ?
Francesco Bartoli
xbartolone at gmail.com
Tue May 31 12:47:45 PDT 2016
Sounds great Alessio! What do you think to go directly with 2.9? I can help with the version update if you need.
Francesco
Il giorno 31/mag/2016, alle ore 10:08, Alessio Fabiani <alessio.fabiani at geo-solutions.it> ha scritto:
> Dear all,
> while the Backup & Restore stuff for GeoServer is moving towards the end of development
> (https://github.com/geosolutions-it/geoserver/tree/backup_restore)
> I would like to propose here an update of the GeoServer version on GeoNode master branch too.
> GeoServer is currently at version 2.10 while GeoNode is still using the old 2.7 one.
> Consider also that in few days we plan to start working on an heavy refactoring of the Authorization & Authentication subsystem of GeoNode/GeoServer.
> The new GeoServer versions not only have a lot of new features but also bug-fixes, performance improvements and some heavy refactoring of the code base which allows GeoServer to work much better and be quite versatile.
> I guess we should start thinking to move at least at version 2.8.x of GeoServer if not a newest one.
> I volunteer to update the security plugins if the community agrees on the version update.
> Please let me know what are your thoughts about this topic.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160531/b8268e54/attachment.html>
More information about the geonode-devel
