[GeoNode-devel] Changes to local_settings.py ignored [Windows, Apache]
Francesco Bartoli xbartolone at gmail.com
Wed Nov 2 14:32:35 PDT 2016
+1 to continue with sphinx, but totally agree with Jeff to have a serious session for updating the docs. That should be a priority out of the triage in my opinion.
Francesco
Il giorno 02/nov/2016, alle ore 22:22, Sara Safavi <ssafavi at boundlessgeo.com> ha scritto:
> (minus geonode-users, as bikeshed colors are Serious Dev Business)
> +1 Jeff, re: just edit existing docs. When did Sphinx stop being "modern", anyway?
> On Wed, Nov 2, 2016 at 4:13 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> How about instead of changing the method, someone just sit down and write up the changes to the docs necessary. We have a management commands page in the docs, its just horribly out of date. The easiest way to change that is to just to edit the docs.
> On Wed, Nov 2, 2016 at 11:01 AM, Patrick Dufour <pjdufour.dev at gmail.com> wrote:
> On the first day of the Summit, we should decide on a new more moden method for documentation and whiteboard a new UX flow for geonode.org.  I can definitely see us having a "management commands" section of the website.
> Regards,
> Patrick Dufour
> On Nov 2, 2016 1:11 PM, "Francesco Bartoli" <xbartolone at gmail.com> wrote:
> Surely, maybe we can handle that during the sprint at the latest
> Cheers,
> Francesco
> Sent from Nylas N1, the extensible, open source mail client.
> On nov 2 2016, at 1:07 pm, Alessio Fabiani <alessio.fabiani at geo-solutions.it> wrote:
> Hi Francesco,
> good catch. Those commands are not documented on the official GeoNode documentation (as far as I can see).
> It would be good to have them documented.
> I'll try to find some time to test them and improve the documentation. I have no much time in these days though, so if someone would like to do that in the meantime it will be very welcomed.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> Hi Alessio,
> I think the geonode updatemaplayerip [1] might be of help
> Ciao,
> Francesco
> [1] https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py
> On nov 2 2016, at 11:49 am, Alessio Fabiani <alessio.fabiani at geo-solutions.it> wrote:
> Hello Nicolai,
> I'm going to maintain the discussion on the mailing list so that it can be useful for other users too in the future.
> The problem should be related only to the maps. I'm currently not aware of a quick command to do this. At this point you have two options:
> 1. Delete only the old maps and rebuild them from scratch.
> 2. Manually update the GeoServer ip address on the database -> main geonode database, table "maps_maplayer"
> Best Regards,
> Alessio Fabiani.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com> wrote:
> Dear Alessio,
> Thank you so much for your reply, this is really driving me nuts :)
> I just tested it out, and you were spot on - it's only the old maps that have this issue. New maps created after changing the URL work perfectly. THANK YOU!!! This is such a relief.
> Do you know if there's any way to update the configuration in the database? Or should I re-upload all the data?
> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it>:
> Dear Nicolai,
> is the problem related to the new layers also or just the old ones? Can you please describe exactly your test-case?
> The thing is... if you are trying to expose your saved maps, consider that the configuration is stored on the database. Therefore if you created those maps with the old ip most probably the configuration still has the latter recored on the DB.
> Best Regards,
> Alessio Fabiani.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com> wrote:
> Hi,
> We're trying to open our Geonode installation to the public, and have done the necessary DNS stuff. As such, our Geonode is able to serve static files (html etc.) to outside the internal network, but the url for WMS services etc. still seems to be configured to the localhost.
> As such, users can view the Geonode front-end but cannot be served WMS/WFS content from our geoserver (these show up as bad tiles in geoexplorer).
> I tried to solve this by editing local_settings.py in C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the "PUBLIC_LOCATION" key in the OGC dictionary.
> The big problem is that no matter what I change in settings.py or local_settings.py, how many times I restart Apache/Tomcat/the whole server, delete .pyc files to be regenerated etc., the changes are never reflected in the actual OGC configuration. I don't understand where the problem lies!
> I've even attempted to delete settings.py without incident, so it's like the files are cached somewhere (perhaps in the bowels of Apache?)
> I would be most grateful for any ideas, because I've almost exhausted the list of buttons to push :/
> Best,
> Nicolai
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161102/e8292bc7/attachment-0001.html>
More information about the geonode-devel mailing list
