[GeoNode-devel] [GeoNode-users] Changes to local_settings.py ignored [Windows, Apache]
Simone Dalmasso simone.dalmasso at gmail.com
Wed Nov 2 14:35:22 PDT 2016
I agree we have lot of things in the docs already they just need to be
reorganized. I "volunteer" to commit one (half?) day during the summit.
Il mercoledì 2 novembre 2016, Sara Safavi <ssafavi at boundlessgeo.com> ha
scritto:
> *(minus geonode-users, as bikeshed colors are Serious Dev Business)*
> +1 Jeff, re: just edit existing docs. When did Sphinx stop being "modern",
> anyway?
> On Wed, Nov 2, 2016 at 4:13 PM, Jeffrey Johnson <ortelius at gmail.com
> <javascript:_e(%7B%7D,'cvml','ortelius at gmail.com');>> wrote:
>> How about instead of changing the method, someone just sit down and write
>> up the changes to the docs necessary. We have a management commands page in
>> the docs, its just horribly out of date. The easiest way to change that is
>> to just to edit the docs.
>> On Wed, Nov 2, 2016 at 11:01 AM, Patrick Dufour <pjdufour.dev at gmail.com
>> <javascript:_e(%7B%7D,'cvml','pjdufour.dev at gmail.com');>> wrote:
>>> On the first day of the Summit, we should decide on a new more moden
>>> method for documentation and whiteboard a new UX flow for geonode.org.
>>> I can definitely see us having a "management commands" section of the
>>> website.
>>> Regards,
>>> Patrick Dufour
>>> On Nov 2, 2016 1:11 PM, "Francesco Bartoli" <xbartolone at gmail.com
>>> <javascript:_e(%7B%7D,'cvml','xbartolone at gmail.com');>> wrote:
>>>> Surely, maybe we can handle that during the sprint at the latest
>>>> Cheers,
>>>> Francesco
>>>> Sent from Nylas N1
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-644a5635-880d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>> the extensible, open source mail client.
>>>> On nov 2 2016, at 1:07 pm, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it
>>>> <javascript:_e(%7B%7D,'cvml','alessio.fabiani at geo-solutions.it');>>
>>>> wrote:
>>>>> Hi Francesco,
>>>>> good catch. Those commands are not documented on the official GeoNode
>>>>> documentation (as far as I can see).
>>>>> It would be good to have them documented.
>>>>> I'll try to find some time to test them and improve the documentation.
>>>>> I have no much time in these days though, so if someone would like to do
>>>>> that in the meantime it will be very welcomed.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> GeoServer Professional Services from the experts!
>>>>> Visit http://goo.gl/it488V
>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=> for
>>>>> more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A
>>>>> 55054  Massarosa (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313
>>>>> fax:     +39 0584 1660272
>>>>> mob:   +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> http://twitter.com/geosolutions_it
>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>> The information in this message and/or attachments, is intended solely
>>>>> for the attention and use of the named addressee(s) and may be confidential
>>>>> or proprietary in nature or covered by the provisions of privacy act
>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>>> strictly forbidden except previous formal approval of the named
>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>> information in this message that has been received in error. The sender
>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>> made after they were sent or for other risks which arise as a result of
>>>>> e-mail transmission, viruses, etc.
>>>>> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli <
>>>>> Hi Alessio,
>>>>> I think the geonode updatemaplayerip [1] might be of help
>>>>> Ciao,
>>>>> Francesco
>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/m
>>>>> aps/management/commands/updatemaplayerip.py
>>>>> <https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> Sent from Nylas N1
>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-56e8c7e4-998d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>> On nov 2 2016, at 11:49 am, Alessio Fabiani <
>>>>> wrote:
>>>>> Hello Nicolai,
>>>>> I'm going to maintain the discussion on the mailing list so that it
>>>>> can be useful for other users too in the future.
>>>>> The problem should be related only to the maps. I'm currently not
>>>>> aware of a quick command to do this. At this point you have two options:
>>>>> 1. Delete only the old maps and rebuild them from scratch.
>>>>> 2. Manually update the GeoServer ip address on the database -> main
>>>>> geonode database, table "maps_maplayer"
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> for more information.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com
>>>>> <javascript:_e(%7B%7D,'cvml','nkcryer at gmail.com');>> wrote:
>>>>> Dear Alessio,
>>>>> Thank you so much for your reply, this is really driving me nuts :)
>>>>> I just tested it out, and you were spot on - it's only the old maps
>>>>> that have this issue. New maps created after changing the URL work
>>>>> perfectly. THANK YOU!!! This is such a relief.
>>>>> Do you know if there's any way to update the configuration in the
>>>>> database? Or should I re-upload all the data?
>>>>> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <
>>>>> <javascript:_e(%7B%7D,'cvml','alessio.fabiani at geo-solutions.it');>>:
>>>>> Dear Nicolai,
>>>>> is the problem related to the new layers also or just the old ones?
>>>>> Can you please describe exactly your test-case?
>>>>> The thing is... if you are trying to expose your saved maps, consider
>>>>> that the configuration is stored on the database. Therefore if you created
>>>>> those maps with the old ip most probably the configuration still has the
>>>>> latter recored on the DB.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com
>>>>> Hi,
>>>>> We're trying to open our Geonode installation to the public, and have
>>>>> done the necessary DNS stuff. As such, our Geonode is able to serve static
>>>>> files (html etc.) to outside the internal network, but the url for WMS
>>>>> services etc. still seems to be configured to the localhost.
>>>>> As such, users can view the Geonode front-end but cannot be served
>>>>> WMS/WFS content from our geoserver (these show up as bad tiles in
>>>>> geoexplorer).
>>>>> I tried to solve this by editing local_settings.py in
>>>>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the
>>>>> "PUBLIC_LOCATION" key in the OGC dictionary.
>>>>> The big problem is that no matter what I change in settings.py or
>>>>> local_settings.py, how many times I restart Apache/Tomcat/the whole server,
>>>>> delete .pyc files to be regenerated etc., the changes are never reflected
>>>>> in the actual OGC configuration. I don't understand where the problem lies!
>>>>> I've even attempted to delete settings.py without incident, so it's
>>>>> like the files are cached somewhere (perhaps in the bowels of Apache?)
>>>>> I would be most grateful for any ideas, because I've almost exhausted
>>>>> the list of buttons to push :/
>>>>> Best,
>>>>> Nicolai
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> <javascript:_e(%7B%7D,'cvml','geonode-devel at lists.osgeo.org');>
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161102/d9957cce/attachment-0001.html>
More information about the geonode-devel mailing list
