[GeoNode-devel] [GeoNode-users] Changes to local_settings.py ignored [Windows, Apache]
Jeffrey Johnson ortelius at gmail.com
Wed Nov 2 14:44:06 PDT 2016
+1 to 'just doing it' vs talking about it. Im happy to spend time to work
on the docs too, it is badly needed.
On Wed, Nov 2, 2016 at 2:35 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> I agree we have lot of things in the docs already they just need to be
> reorganized. I "volunteer" to commit one (half?) day during the summit.
> Il mercoledì 2 novembre 2016, Sara Safavi <ssafavi at boundlessgeo.com> ha
> scritto:
>> *(minus geonode-users, as bikeshed colors are Serious Dev Business)*
>> +1 Jeff, re: just edit existing docs. When did Sphinx stop being
>> "modern", anyway?
>> On Wed, Nov 2, 2016 at 4:13 PM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>>> How about instead of changing the method, someone just sit down and
>>> write up the changes to the docs necessary. We have a management commands
>>> page in the docs, its just horribly out of date. The easiest way to change
>>> that is to just to edit the docs.
>>> On Wed, Nov 2, 2016 at 11:01 AM, Patrick Dufour <pjdufour.dev at gmail.com>
>>> wrote:
>>>> On the first day of the Summit, we should decide on a new more moden
>>>> method for documentation and whiteboard a new UX flow for geonode.org.
>>>> I can definitely see us having a "management commands" section of the
>>>> website.
>>>> Regards,
>>>> Patrick Dufour
>>>> On Nov 2, 2016 1:11 PM, "Francesco Bartoli" <xbartolone at gmail.com>
>>>> wrote:
>>>>> Surely, maybe we can handle that during the sprint at the latest
>>>>> Cheers,
>>>>> Francesco
>>>>> Sent from Nylas N1
>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-644a5635-880d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>> the extensible, open source mail client.
>>>>> On nov 2 2016, at 1:07 pm, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Hi Francesco,
>>>>>> good catch. Those commands are not documented on the official GeoNode
>>>>>> documentation (as far as I can see).
>>>>>> It would be good to have them documented.
>>>>>> I'll try to find some time to test them and improve the
>>>>>> documentation. I have no much time in these days though, so if someone
>>>>>> would like to do that in the meantime it will be very welcomed.
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> GeoServer Professional Services from the experts!
>>>>>> Visit http://goo.gl/it488V
>>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A
>>>>>> 55054  Massarosa (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax:     +39 0584 1660272
>>>>>> mob:   +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> http://twitter.com/geosolutions_it
>>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>> The information in this message and/or attachments, is intended
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>> information in this message that has been received in error. The sender
>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>> e-mail transmission, viruses, etc.
>>>>>> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli <
>>>>>> xbartolone at gmail.com> wrote:
>>>>>> Hi Alessio,
>>>>>> I think the geonode updatemaplayerip [1] might be of help
>>>>>> Ciao,
>>>>>> Francesco
>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/m
>>>>>> aps/management/commands/updatemaplayerip.py
>>>>>> <https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> Sent from Nylas N1
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-56e8c7e4-998d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>>> On nov 2 2016, at 11:49 am, Alessio Fabiani <
>>>>>> Hello Nicolai,
>>>>>> I'm going to maintain the discussion on the mailing list so that it
>>>>>> can be useful for other users too in the future.
>>>>>> The problem should be related only to the maps. I'm currently not
>>>>>> aware of a quick command to do this. At this point you have two options:
>>>>>> 1. Delete only the old maps and rebuild them from scratch.
>>>>>> 2. Manually update the GeoServer ip address on the database -> main
>>>>>> geonode database, table "maps_maplayer"
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com>
>>>>>> wrote:
>>>>>> Dear Alessio,
>>>>>> Thank you so much for your reply, this is really driving me nuts :)
>>>>>> I just tested it out, and you were spot on - it's only the old maps
>>>>>> that have this issue. New maps created after changing the URL work
>>>>>> perfectly. THANK YOU!!! This is such a relief.
>>>>>> Do you know if there's any way to update the configuration in the
>>>>>> database? Or should I re-upload all the data?
>>>>>> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>> Dear Nicolai,
>>>>>> is the problem related to the new layers also or just the old ones?
>>>>>> Can you please describe exactly your test-case?
>>>>>> The thing is... if you are trying to expose your saved maps, consider
>>>>>> that the configuration is stored on the database. Therefore if you created
>>>>>> those maps with the old ip most probably the configuration still has the
>>>>>> latter recored on the DB.
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com>
>>>>>> wrote:
>>>>>> Hi,
>>>>>> We're trying to open our Geonode installation to the public, and have
>>>>>> done the necessary DNS stuff. As such, our Geonode is able to serve static
>>>>>> files (html etc.) to outside the internal network, but the url for WMS
>>>>>> services etc. still seems to be configured to the localhost.
>>>>>> As such, users can view the Geonode front-end but cannot be served
>>>>>> WMS/WFS content from our geoserver (these show up as bad tiles in
>>>>>> geoexplorer).
>>>>>> I tried to solve this by editing local_settings.py in
>>>>>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the
>>>>>> "PUBLIC_LOCATION" key in the OGC dictionary.
>>>>>> The big problem is that no matter what I change in settings.py or
>>>>>> local_settings.py, how many times I restart Apache/Tomcat/the whole server,
>>>>>> delete .pyc files to be regenerated etc., the changes are never reflected
>>>>>> in the actual OGC configuration. I don't understand where the problem lies!
>>>>>> I've even attempted to delete settings.py without incident, so it's
>>>>>> like the files are cached somewhere (perhaps in the bowels of Apache?)
>>>>>> I would be most grateful for any ideas, because I've almost exhausted
>>>>>> the list of buttons to push :/
>>>>>> Best,
>>>>>> Nicolai
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161102/35e63437/attachment-0001.html>
More information about the geonode-devel mailing list
