[GeoNode-devel] [GeoNode-users] Changes to local_settings.py ignored [Windows, Apache]
Patrick Dufour pjdufour.dev at gmail.com
Thu Nov 3 01:22:30 PDT 2016
There's an underlying structural issue with keeping our docs up to date.
RST is much less approachable than markdown, but that's not the primary
challenge.  GeoNode packages a lot under the hood, so there's a wider
surface area we should document, more so than other open source GIS
projects.
We shouldn't be bound to a solution that is optimized for source code
documentation when the most pressing fixes need to happen to admin/dev/user
manuals.  We don't even document internal APIs anyway.  One shouldn't need
to be a python wizard to fix typos or update screenshots.
Creating a new geonode.org website is as important IMO, but the solution
for website can be different than solution to docs.
Regards,
Patrick Dufour
On Nov 2, 2016 10:44 PM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
> +1 to 'just doing it' vs talking about it. Im happy to spend time to work
> on the docs too, it is badly needed.
> On Wed, Nov 2, 2016 at 2:35 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> I agree we have lot of things in the docs already they just need to be
>> reorganized. I "volunteer" to commit one (half?) day during the summit.
>> Il mercoledì 2 novembre 2016, Sara Safavi <ssafavi at boundlessgeo.com> ha
>> scritto:
>>> *(minus geonode-users, as bikeshed colors are Serious Dev Business)*
>>> +1 Jeff, re: just edit existing docs. When did Sphinx stop being
>>> "modern", anyway?
>>> On Wed, Nov 2, 2016 at 4:13 PM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>>> How about instead of changing the method, someone just sit down and
>>>> write up the changes to the docs necessary. We have a management commands
>>>> page in the docs, its just horribly out of date. The easiest way to change
>>>> that is to just to edit the docs.
>>>> On Wed, Nov 2, 2016 at 11:01 AM, Patrick Dufour <pjdufour.dev at gmail.com
>>>> > wrote:
>>>>> On the first day of the Summit, we should decide on a new more moden
>>>>> method for documentation and whiteboard a new UX flow for geonode.org.
>>>>> I can definitely see us having a "management commands" section of the
>>>>> website.
>>>>> Regards,
>>>>> Patrick Dufour
>>>>> On Nov 2, 2016 1:11 PM, "Francesco Bartoli" <xbartolone at gmail.com>
>>>>> wrote:
>>>>>> Surely, maybe we can handle that during the sprint at the latest
>>>>>> Cheers,
>>>>>> Francesco
>>>>>> Sent from Nylas N1
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-644a5635-880d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>>> the extensible, open source mail client.
>>>>>> On nov 2 2016, at 1:07 pm, Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>> Hi Francesco,
>>>>>>> good catch. Those commands are not documented on the official
>>>>>>> GeoNode documentation (as far as I can see).
>>>>>>> It would be good to have them documented.
>>>>>>> I'll try to find some time to test them and improve the
>>>>>>> documentation. I have no much time in these days though, so if someone
>>>>>>> would like to do that in the meantime it will be very welcomed.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> GeoServer Professional Services from the experts!
>>>>>>> Visit http://goo.gl/it488V
>>>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A
>>>>>>> 55054  Massarosa (LU)
>>>>>>> Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax:     +39 0584 1660272
>>>>>>> mob:   +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>> The information in this message and/or attachments, is intended
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>> information in this message that has been received in error. The sender
>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>> e-mail transmission, viruses, etc.
>>>>>>> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli <
>>>>>>> xbartolone at gmail.com> wrote:
>>>>>>> Hi Alessio,
>>>>>>> I think the geonode updatemaplayerip [1] might be of help
>>>>>>> Ciao,
>>>>>>> Francesco
>>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/m
>>>>>>> aps/management/commands/updatemaplayerip.py
>>>>>>> <https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> Sent from Nylas N1
>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-56e8c7e4-998d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>>>> On nov 2 2016, at 11:49 am, Alessio Fabiani <
>>>>>>> Hello Nicolai,
>>>>>>> I'm going to maintain the discussion on the mailing list so that it
>>>>>>> can be useful for other users too in the future.
>>>>>>> The problem should be related only to the maps. I'm currently not
>>>>>>> aware of a quick command to do this. At this point you have two options:
>>>>>>> 1. Delete only the old maps and rebuild them from scratch.
>>>>>>> 2. Manually update the GeoServer ip address on the database -> main
>>>>>>> geonode database, table "maps_maplayer"
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com>
>>>>>>> wrote:
>>>>>>> Dear Alessio,
>>>>>>> Thank you so much for your reply, this is really driving me nuts :)
>>>>>>> I just tested it out, and you were spot on - it's only the old maps
>>>>>>> that have this issue. New maps created after changing the URL work
>>>>>>> perfectly. THANK YOU!!! This is such a relief.
>>>>>>> Do you know if there's any way to update the configuration in the
>>>>>>> database? Or should I re-upload all the data?
>>>>>>> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>> Dear Nicolai,
>>>>>>> is the problem related to the new layers also or just the old ones?
>>>>>>> Can you please describe exactly your test-case?
>>>>>>> The thing is... if you are trying to expose your saved maps,
>>>>>>> consider that the configuration is stored on the database. Therefore if you
>>>>>>> created those maps with the old ip most probably the configuration still
>>>>>>> has the latter recored on the DB.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com>
>>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> We're trying to open our Geonode installation to the public, and
>>>>>>> have done the necessary DNS stuff. As such, our Geonode is able to serve
>>>>>>> static files (html etc.) to outside the internal network, but the url for
>>>>>>> WMS services etc. still seems to be configured to the localhost.
>>>>>>> As such, users can view the Geonode front-end but cannot be served
>>>>>>> WMS/WFS content from our geoserver (these show up as bad tiles in
>>>>>>> geoexplorer).
>>>>>>> I tried to solve this by editing local_settings.py in
>>>>>>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the
>>>>>>> "PUBLIC_LOCATION" key in the OGC dictionary.
>>>>>>> The big problem is that no matter what I change in settings.py or
>>>>>>> local_settings.py, how many times I restart Apache/Tomcat/the whole server,
>>>>>>> delete .pyc files to be regenerated etc., the changes are never reflected
>>>>>>> in the actual OGC configuration. I don't understand where the problem lies!
>>>>>>> I've even attempted to delete settings.py without incident, so it's
>>>>>>> like the files are cached somewhere (perhaps in the bowels of Apache?)
>>>>>>> I would be most grateful for any ideas, because I've almost
>>>>>>> exhausted the list of buttons to push :/
>>>>>>> Best,
>>>>>>> Nicolai
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161103/20a73baa/attachment-0001.html>
More information about the geonode-devel mailing list
