[GeoNode-devel] [GeoNode-users] Changes to local_settings.py	ignored [Windows, Apache]
    Sara Safavi
    ssafavi at boundlessgeo.com
    Thu Nov  3 08:46:20 PDT 2016
I started responding to this more deeply, but realized it's a trap. Let's
not go down the rabbithole of debating personal feelings on ReST vs MD,
yeah?
GeoNode has a docs system already in-place, which requires minimal effort
to release an update. It takes no particular wizardry to update a typo in
our existing docs, so long as you are passingly familiar with Git+GitHub
itself. Since the actual Python language has a significantly "wider surface
area" and yet finds the same system we use sufficient for user docs
<https://docs.python.org> - why argue further.
Bottom line, it sounds like we've all agreed that some human-power should
be spent on updating what we currently have in place. Let's just *do* that,
and not waste time endlessly debating paint colors. :)
On Thu, Nov 3, 2016 at 3:22 AM, Patrick Dufour <pjdufour.dev at gmail.com>
wrote:
> There's an underlying structural issue with keeping our docs up to date.
> RST is much less approachable than markdown, but that's not the primary
> challenge.  GeoNode packages a lot under the hood, so there's a wider
> surface area we should document, more so than other open source GIS
> projects.
> We shouldn't be bound to a solution that is optimized for source code
> documentation when the most pressing fixes need to happen to admin/dev/user
> manuals.  We don't even document internal APIs anyway.  One shouldn't need
> to be a python wizard to fix typos or update screenshots.
> Creating a new geonode.org website is as important IMO, but the solution
> for website can be different than solution to docs.
> Regards,
> Patrick Dufour
> On Nov 2, 2016 10:44 PM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
>> +1 to 'just doing it' vs talking about it. Im happy to spend time to work
>> on the docs too, it is badly needed.
>> On Wed, Nov 2, 2016 at 2:35 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> I agree we have lot of things in the docs already they just need to be
>>> reorganized. I "volunteer" to commit one (half?) day during the summit.
>>> Il mercoledì 2 novembre 2016, Sara Safavi <ssafavi at boundlessgeo.com> ha
>>> scritto:
>>>> *(minus geonode-users, as bikeshed colors are Serious Dev Business)*
>>>> +1 Jeff, re: just edit existing docs. When did Sphinx stop being
>>>> "modern", anyway?
>>>> On Wed, Nov 2, 2016 at 4:13 PM, Jeffrey Johnson <ortelius at gmail.com>
>>>> wrote:
>>>>> How about instead of changing the method, someone just sit down and
>>>>> write up the changes to the docs necessary. We have a management commands
>>>>> page in the docs, its just horribly out of date. The easiest way to change
>>>>> that is to just to edit the docs.
>>>>> On Wed, Nov 2, 2016 at 11:01 AM, Patrick Dufour <
>>>>> pjdufour.dev at gmail.com> wrote:
>>>>>> On the first day of the Summit, we should decide on a new more moden
>>>>>> method for documentation and whiteboard a new UX flow for geonode.org.
>>>>>> I can definitely see us having a "management commands" section of the
>>>>>> website.
>>>>>> Regards,
>>>>>> Patrick Dufour
>>>>>> On Nov 2, 2016 1:11 PM, "Francesco Bartoli" <xbartolone at gmail.com>
>>>>>> wrote:
>>>>>>> Surely, maybe we can handle that during the sprint at the latest
>>>>>>> Cheers,
>>>>>>> Francesco
>>>>>>> Sent from Nylas N1
>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-644a5635-880d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>>>> the extensible, open source mail client.
>>>>>>> On nov 2 2016, at 1:07 pm, Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>> Hi Francesco,
>>>>>>>> good catch. Those commands are not documented on the official
>>>>>>>> GeoNode documentation (as far as I can see).
>>>>>>>> It would be good to have them documented.
>>>>>>>> I'll try to find some time to test them and improve the
>>>>>>>> documentation. I have no much time in these days though, so if someone
>>>>>>>> would like to do that in the meantime it will be very welcomed.
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> GeoServer Professional Services from the experts!
>>>>>>>> Visit http://goo.gl/it488V
>>>>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> for more information.
>>>>>>>> Ing. Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> Founder/Technical Lead
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Via di Montramito 3/A
>>>>>>>> 55054  Massarosa (LU)
>>>>>>>> Italy
>>>>>>>> phone: +39 0584 962313
>>>>>>>> fax:     +39 0584 1660272
>>>>>>>> mob:   +39 331 6233686
>>>>>>>> http://www.geo-solutions.it
>>>>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli <
>>>>>>>> xbartolone at gmail.com> wrote:
>>>>>>>> Hi Alessio,
>>>>>>>> I think the geonode updatemaplayerip [1] might be of help
>>>>>>>> Ciao,
>>>>>>>> Francesco
>>>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/m
>>>>>>>> aps/management/commands/updatemaplayerip.py
>>>>>>>> <https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> Sent from Nylas N1
>>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-56e8c7e4-998d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>>>>>> On nov 2 2016, at 11:49 am, Alessio Fabiani <
>>>>>>>> Hello Nicolai,
>>>>>>>> I'm going to maintain the discussion on the mailing list so that it
>>>>>>>> can be useful for other users too in the future.
>>>>>>>> The problem should be related only to the maps. I'm currently not
>>>>>>>> aware of a quick command to do this. At this point you have two options:
>>>>>>>> 1. Delete only the old maps and rebuild them from scratch.
>>>>>>>> 2. Manually update the GeoServer ip address on the database -> main
>>>>>>>> geonode database, table "maps_maplayer"
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Dear Alessio,
>>>>>>>> Thank you so much for your reply, this is really driving me nuts :)
>>>>>>>> I just tested it out, and you were spot on - it's only the old maps
>>>>>>>> that have this issue. New maps created after changing the URL work
>>>>>>>> perfectly. THANK YOU!!! This is such a relief.
>>>>>>>> Do you know if there's any way to update the configuration in the
>>>>>>>> database? Or should I re-upload all the data?
>>>>>>>> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <
>>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>> Dear Nicolai,
>>>>>>>> is the problem related to the new layers also or just the old ones?
>>>>>>>> Can you please describe exactly your test-case?
>>>>>>>> The thing is... if you are trying to expose your saved maps,
>>>>>>>> consider that the configuration is stored on the database. Therefore if you
>>>>>>>> created those maps with the old ip most probably the configuration still
>>>>>>>> has the latter recored on the DB.
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Hi,
>>>>>>>> We're trying to open our Geonode installation to the public, and
>>>>>>>> have done the necessary DNS stuff. As such, our Geonode is able to serve
>>>>>>>> static files (html etc.) to outside the internal network, but the url for
>>>>>>>> WMS services etc. still seems to be configured to the localhost.
>>>>>>>> As such, users can view the Geonode front-end but cannot be served
>>>>>>>> WMS/WFS content from our geoserver (these show up as bad tiles in
>>>>>>>> geoexplorer).
>>>>>>>> I tried to solve this by editing local_settings.py in
>>>>>>>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the
>>>>>>>> "PUBLIC_LOCATION" key in the OGC dictionary.
>>>>>>>> The big problem is that no matter what I change in settings.py or
>>>>>>>> local_settings.py, how many times I restart Apache/Tomcat/the whole server,
>>>>>>>> delete .pyc files to be regenerated etc., the changes are never reflected
>>>>>>>> in the actual OGC configuration. I don't understand where the problem lies!
>>>>>>>> I've even attempted to delete settings.py without incident, so it's
>>>>>>>> like the files are cached somewhere (perhaps in the bowels of Apache?)
>>>>>>>> I would be most grateful for any ideas, because I've almost
>>>>>>>> exhausted the list of buttons to push :/
>>>>>>>> Best,
>>>>>>>> Nicolai
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161103/99008bf9/attachment-0001.html>
More information about the geonode-devel
