[GeoNode-devel] Geonode 2.4 on Ubuntu 16.04 - unmet dependencies
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Nov 2 23:32:39 PDT 2016
not sure that's the issue because the only place geonode 2.5 is available
is in the testing ppa moreover the error is that geonode depends on django
<=1.7 but the 1.8 is to be installed and I think is because the 1.6 might
not be available for xenial
https://launchpad.net/ubuntu/+source/python-django.
I would suggest you to go for the manual installation under a virtualenv,
the doc is for the 2.4 but the process is very similar
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
hope this helps
2016-11-03 0:01 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au>:
> Hi devs
> No reply on geonode-users, so I’m trying here.
> Thanks
> Jonathan
> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *On
> Behalf Of *Jonathan Doig
> *Sent:* Wednesday, 2 November 2016 5:05 PM
> *To:* geonode-users at lists.osgeo.org
> *Subject:* [GeoNode-users] Geonode 2.4 on Ubuntu 16.04
> Hi
> I’m trying to install Geonode 2.4 on Ubuntu 16.04, being new to both.
> I’m stepping through the OSGeoLive install_geonode.sh script following
> this advice from Angelos Tzotsos on Aug 18:
> Ø GeoNode 2.4 works fine on Xenial.
> Ø The Debian packaging has been updated accordingly.
> Ø Please check the OSGeoLive install script to find out how to install:
> Ø https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonode.sh
> However line 50:
> apt-get --assume-yes install python-geonode libapache2-mod-wsgi curl
> Is giving trouble:
> The following packages have unmet dependencies:
> python-geonode : Depends: python-django (<= 1.7) but 1.8.7-1ubuntu5.2 is
> to be installed
> Recommends: transifex-client but it is not going to be
> installed
> E: Unable to correct problems, you have held broken packages.
> I think it’s because python-geonode is v2.5.5 which uses django 1.8, where
> I want v2.4 which needs django 1.6.
> I tried specifying a geonode version: --target_release ‘2.4*’ or /release
> or /stable but nothing was found.
> Advice please.
> Thanks
> *Jonathan Doig*
> *Software Engineer – Spatial Systems*
> *City Futures Research Centre*
> *UNSW Built Environment *
> cityfutures.net.au <http://cityfutures.be.unsw.edu.au/>
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161103/9d8d1c71/attachment-0001.html>
More information about the geonode-devel
