[GeoNode-devel] Upgrade of Geoserver from 2.5 to 2.9
Dimitris Karakostis
karakostis.dimitris at gmail.com
Thu Oct 27 09:45:51 PDT 2016
Thanks for your answer Alessio,
Is the GeoNode 2.4 version also based on Geoserver 2.9.x?
Regarding Tomcat, which version is recommended?
Just to starting forming an idea of the steps to be followed:
1) backup geoserver files.
2) update to recommended Tomcat version
3) update Java to 8+
4) deploy Geoserver 2.9
Thanks a lot.
Dimitris
On Thu, Oct 27, 2016 at 5:00 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear Dimitris,
> the current master branch of https://github.com/GeoNode/
> geoserver-geonode-ext is already based on GeoServer 2.9.x.
> Also here http://build.geonode.org/geoserver/latest/ you can also find
> the compiled version already along with the upgraded data dir.
> The only advice is that you will need to use Java 8+ to let it working.
> Also, I would like to point out that the GeoNode 2.5+ already relies on
> the the new GeoServer version.
> Again pay attention to the Java version, GeoServer 2.9+ works *only* with
> Java 8+.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Oct 27, 2016 at 4:54 PM, Dimitris Karakostis <
> karakostis.dimitris at gmail.com> wrote:
>> Hello all,
>> I need some advice regarding upgrading our WFP GeoNode Geoserver and it
>> would be really great if you can help me.
>> Our current Geoserver version is 2.5. We want to update it to 2.9. Has
>> anyone of you tried to do an upgrade like this in the past?
>> If yes, have you perhaps documented the process or can you provide with
>> some advice regarding the different steps? I understand the challenge is
>> not upgrading Geoserver its self but the different components, which
>> interact with GeoNode (authentication etc.)
>> Any advice is mostly welcome.
>> Thanks a lot.
>> Dimitris
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161027/035c1912/attachment.html>
More information about the geonode-devel
