[GeoNode-devel] Upgrade of Geoserver from 2.5 to 2.9
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Oct 27 08:00:08 PDT 2016
Dear Dimitris,
the current master branch of
https://github.com/GeoNode/geoserver-geonode-ext is already based on
GeoServer 2.9.x.
Also here http://build.geonode.org/geoserver/latest/ you can also find the
compiled version already along with the upgraded data dir.
The only advice is that you will need to use Java 8+ to let it working.
Also, I would like to point out that the GeoNode 2.5+ already relies on the
the new GeoServer version.
Again pay attention to the Java version, GeoServer 2.9+ works *only* with
Java 8+.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Thu, Oct 27, 2016 at 4:54 PM, Dimitris Karakostis <
karakostis.dimitris at gmail.com> wrote:
> Hello all,
> I need some advice regarding upgrading our WFP GeoNode Geoserver and it
> would be really great if you can help me.
> Our current Geoserver version is 2.5. We want to update it to 2.9. Has
> anyone of you tried to do an upgrade like this in the past?
> If yes, have you perhaps documented the process or can you provide with
> some advice regarding the different steps? I understand the challenge is
> not upgrading Geoserver its self but the different components, which
> interact with GeoNode (authentication etc.)
> Any advice is mostly welcome.
> Thanks a lot.
> Dimitris
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161027/40cb993a/attachment.html>
More information about the geonode-devel
