[GeoNode-devel] Communication between GeoServer and GeoNode fails
Paolo Corti pcorti at gmail.com
Mon Sep 12 12:48:09 PDT 2016
Hi Michael
Did you change the GeoServer administrative password?
In that case you may need to sync it with the Django settings file:
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L522
If that was not the case, make sure to read this (configure GeoServer section):
http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html
hope it helps
p
On Mon, Sep 12, 2016 at 2:47 PM, Michael Wagner <mwagner at allspatial.info> wrote:
> Hi there,
> Trying to change a layer's style in GeoNode leads to an error message "Error
> saving style" and the style is never changed. Checking the GeoServer logs
> shows the issue as follows:
> WARN [geonode.security] - Error connecting to the GeoNode server for
> authentication purposes
> org.springframework.security.authentication.AuthenticationServiceException:
> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
> at
> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:62)
> at
> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
> The error occurs on Ubuntu 14.04 with GeoNode 2.4 and GeoServer
> 2.7.4./2.9.1. The full error log is attached to this email.
> I also filed the issue on JIRA:
> https://osgeo-org.atlassian.net/browse/GEOS-7737?filter=-4
> Many thanks for your support,
> Michael
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
