[GeoNode-devel] Communication between GeoServer and GeoNode fails
Francesco Bartoli xbartolone at gmail.com
Mon Sep 12 12:52:48 PDT 2016
Hi Michael,
I saw your jira ticket on geoserver project, however I’m not pretty sure it will be managed since that piece of code comes from the geonode authentication provider [1] that is not part of geoserver itself.
Can you please file the same ticket on that github repo? Did you set up any special security rule when the issue happened?
Thanks,
Francesco
[1] https://github.com/GeoNode/geoserver-geonode-ext
Il giorno 12/set/2016, alle ore 20:47, Michael Wagner <mwagner at allspatial.info> ha scritto:
> Hi there,
> Trying to change a layer's style in GeoNode leads to an error message "Error saving style" and the style is never changed. Checking the GeoServer logs shows the issue as follows:
> WARN [geonode.security] - Error connecting to the GeoNode server for authentication purposes
> org.springframework.security.authentication.AuthenticationServiceException: Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
> at org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:62)
> at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
> The error occurs on Ubuntu 14.04 with GeoNode 2.4 and GeoServer 2.7.4./2.9.1. The full error log is attached to this email.
> I also filed the issue on JIRA:
> https://osgeo-org.atlassian.net/browse/GEOS-7737?filter=-4
> Many thanks for your support,
> Michael
> <geoserver.log>
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160912/91c5ec77/attachment.html>
More information about the geonode-devel mailing list
