[GeoNode-devel] Geoserver connection issue
    Francesco Bartoli
    xbartolone at gmail.com
    Sat Apr  8 14:53:01 PDT 2017
Can you check from the console of the browser what url are you calling? Also what is your geoserver configuration in settings file?
Il giorno 08/apr/2017, alle ore 21:56, Michael Peterman <mpetermangis at gmail.com> ha scritto:
> Thanks everyone for your help. I managed to get it running on a new Ubuntu VM.
> I can upload layers now. However, the uploaded layers don't display correctly in the map. The background (bing maps or OpenStreetMap) displays fine, but the vector tiles are not rendered correctly. I am uploading zipped WGS84 shapefiles that worked on a previous installation of Geonode a few months ago. Has anyone else seen this issue?
> <image.png>
> On Thu, Apr 6, 2017 at 2:11 AM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> The database "geonode" is for the configuration data of django application while "geonode_data" is for the spatial data which will be uploaded.
> So in geoserver you have to configure the latter.
> Hope this helps
> Francesco
> 6 apr 2017, 03:14 +0200, Michael Peterman <mpetermangis at gmail.com>, ha scritto:
>> The datastore was configured to use the geonode db on a Postgres backend, as per the instructions. The only thing I'm not sure about--is the database supposed to be "geonode" or "geonode_data"? Here's a screenshot of the settings:
>> <image.png>
>> In any case I will try installing this again on a fresh VM.
>> Thanks,
>> Michael
>> On Wed, Apr 5, 2017 at 6:40 AM, Francesco Bartoli <xbartolone at gmail.com> wrote:
>> In this way you are using the dev environment which by default is relying on a sqlite database. I'm assuming you changed the default settings and have configured the geonode-data database. In this case what is the configuration of the datastore for that in geoserver?
>> Can you please check it using the UI?
>> Thanks
>> Francesco
>> 5 apr 2017, 02:31 +0200, Michael Peterman <mpetermangis at gmail.com>, ha scritto:
>>> Hi Francesco,
>>> Yes I ran that command. Output is:
>>> ---> pavement.setup
>>> ---> pavement.setup_geoserver
>>> rmtree geoserver/data
>>> GeoNode development environment successfully set up.If you have not set up an administrative account, please do so now. Use "paver start" to start up the server.
>>> Geoserver is version 2.7.4 on Java  1.7.0_121 (OpenJDK 64-Bit Server VM)
>>> Any other ideas for what I can try?
>>> Thanks again,
>>> Michael
>>> On Tue, Apr 4, 2017 at 1:46 AM, Francesco Bartoli <xbartolone at gmail.com> wrote:
>>> Dear Micheal,
>>> did you run the command “sudo paver setup” ? If not what geoserver did you install?
>>> Francesco
>>> Il giorno 04/apr/2017, alle ore 01:39, Michael Peterman <mpetermangis at gmail.com> ha scritto:
>>>> Hi,
>>>> I am installing a custom copy of Geonode 2.4, as per these instructions:
>>>> http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/install_geonode_application.html
>>>> I pulled from this git branch: https://github.com/GeoNode/geonode.git --branch 2.4.x
>>>> and installed on a fresh copy of Ubuntu 14.04 64-bit.
>>>> Everything appears to work fine, but after finishing the installation, the connection between Geoserver and Postgres seems to be broken. Any data that I try to upload to Geonode gives this error: "An exception occurred loading data to PostGIS- java.io.IOException: Error occurred creating table"
>>>> The logs in Geoserver show a series of exceptions like this:
>>>> 2017-04-01 23:55:40,930 WARN [geonode.security] - Error connecting to the GeoNode server for authentication purposes
>>>> org.springframework.security.authentication.AuthenticationServiceException: Communication with GeoNode failed (GeoNodeSessionAuthToken)
>>>> Caused by: java.net.SocketTimeoutException: Read timed out
>>>> I am using the same credentials for the Postgres account (geonode / geonode) that are in the instructions.  Geoserver, Postgres, and Geonode are all hosted on the same machine.
>>>> Thanks in advance to everyone, I really appreciate all the effort that has gone into this project.
>>>> Mike
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170408/1b1e081d/attachment.html>
More information about the geonode-devel
