[GeoNode-devel] geonode REST role service - Adminstrator role dropdown empty
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Dec 20 02:37:22 PST 2017
Nope the geonode address is not a problem, you can use whatever is
accessible.
Did you also restarted GeoServer / Tomcat ?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Dec 20, 2017 at 11:32 AM, Peter Marlow <Peter.Marlow at scisys.co.uk>
wrote:
> Hi Alessio,
> Thanks for the reply!
> It looks like the /api endpoint on my geonode is accessible at
> http://localhost/ and not at http://localhost:8000/. Is this a problem?
> I’ve configured the base URL of the Role Service to be just
> http://localhost/ but I still don’t see the ROLE_ADMIN user in the
> dropdowns.
> GeoNode has a superuser configured with the username ‘admin’, it doesn’t
> have any groups though, do I need to create a group?
> If I open up port 8000 in my apache2 config how would I go about changing
> the GeoNode api to be on port 8000? (is that actually necessary?)
> Thanks,
> Pete
> *From:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
> *Sent:* 20 December 2017 09:18
> *To:* Peter Marlow
> *Cc:* geonode-devel at lists.osgeo.org
> *Subject:* Re: [GeoNode-devel] geonode REST role service - Adminstrator
> role dropdown empty
> Hi,
> the roles are taken from GeoNode.
> You need to be sure that:
> 1. GeoServer can reach GeoNode
> 2. the base url of the role service is correctly pointing to GeoNode
> 3. GeoNode has either an admin user configured and groups
> If still not working you can try to do some curl requests to GeoNode and
> see if it is correctly responding.
> curl -X GET "http://localhost:8000/api/roles"
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
> (LU)
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax:     +39 0584 1660272 <0584%20166%200272>
> mob:   +39 331 6233686 <331%20623%203686>
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Dec 19, 2017 at 6:14 PM, Peter Marlow <Peter.Marlow at scisys.co.uk>
> wrote:
> Hi all,
> I’m configuring geonode/geoserver security using the tutorial here -
> http://docs.geonode.org/en/master/tutorials/admin/
> geoserver_geonode_security/
> The problem I have is that when I create the ‘geonode REST role service’
> both the ‘Administrator role’ and ‘Group administrator role’ dropdowns are
> empty – the tutorial suggests they should contain the value ROLE_ADMIN.
> Any ideas where this ROLE_ADMIN should be configured in order to make it
> available in the dropdowns?
> GEOSERVER VERSION – 2.12-SNAPSHOT
> GEONODE VERSION – 2.6.3
> Thanks,
> Pete
> SCISYS UK Limited. Registered in England and Wales No. 4373530.
> Registered Office: Methuen Park, Chippenham, Wiltshire SN14 0GB, UK.
> Before printing, please think about the environment.
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171220/cb5c7a9b/attachment-0001.html>
More information about the geonode-devel mailing list
