[GeoNode-devel] Geoserver: No AuthenticationProvider on GeoNode Container
Wayner Barrios
wayner at piensa.co
Wed Jan 4 17:39:41 PST 2017
Daniel,
For sure, I did python python manage.py loaddata default_oauth_apps on
Makefile and overwrote IPs on xmls files into geoserver container.
On Wed, Jan 4, 2017 at 6:58 PM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> Wayner,
> Did you ensure that you loaded the fixture?
> In my docker setup I also needed to run some sed statements for the
> security filter and role file for oauth2 in geoserver data dir,
> specifically these -
> sed -i.bak 's at localhost:\(8000\|8080\)@172.16.238.2 at g' \
> /tmp/geoserver/data/security/filter/geonode-oauth2/config.xml
> sed -i.bak 's at localhost:8000 at 172.16.238.2@g' \
> /tmp/geoserver/data/security/role/geonode\ REST\ role\
> service/config.xml && \
> I had run into an issue with GEONODE_LOCKDOWN = True
> https://github.com/GeoNode/geonode/pull/2801
> Cheers!
> Dan
> On Wed, Jan 4, 2017 at 2:12 PM, Wayner Barrios <wayner at piensa.co> wrote:
>> Hi All,
>> I've been trying deployment on docker with the new authentication on
>> docker, and I got the following error.
>> [image: Inline image 1]
>> However, django container and geoserver container are connected in the
>> same network, because I can ping it and curl it. As you can see in the
>> following:
>> root at db8cd2498945:/usr/src/app# ping geoserver
>> PING geoserver (172.23.0.7): 56 data bytes
>> 64 bytes from 172.23.0.7: icmp_seq=0 ttl=64 time=0.349 ms
>> 64 bytes from 172.23.0.7: icmp_seq=1 ttl=64 time=0.194 ms
>> 64 bytes from 172.23.0.7: icmp_seq=2 ttl=64 time=0.135 ms
>> 64 bytes from 172.23.0.7: icmp_seq=3 ttl=64 time=0.210 ms
>> 64 bytes from 172.23.0.7: icmp_seq=4 ttl=64 time=0.126 ms
>> 64 bytes from 172.23.0.7: icmp_seq=5 ttl=64 time=0.163 ms
>> 64 bytes from 172.23.0.7: icmp_seq=6 ttl=64 time=0.150 ms
>> root at db8cd2498945:/usr/src/app# curl geoserver:8080
>> <!DOCTYPE html>
>> <html lang="en">
>> <head>
>> <meta charset="UTF-8" />
>> <title>Apache Tomcat/9.0.0.M13</title>
>> <link href="favicon.ico" rel="icon" type="image/x-icon" />
>> <link href="favicon.ico" rel="shortcut icon" type="image/x-icon" />
>> <link href="tomcat.css" rel="stylesheet" type="text/css" />
>> </head>
>> <body>
>> <div id="wrapper">
>> <div id="navigation" class="curved container">
>> <span id="nav-home"><a href="http://tomcat.apache.org/">Home</a></span>......
>> Does anyone give any solution or the best way to do that? I just followed those steps from GeoSolutions: GeoSolutions_new_GeoServer_setup.txt <https://github.com/GeoNode/geonode/files/685760/GeoSolutions_new_GeoServer_setup.txt>
>> Who can give me support on that?
>> Best,
>> Wayner
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 <(512)%20468-3946> (cell)
> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170104/285fc2ac/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170104/285fc2ac/attachment-0001.png>
More information about the geonode-devel
