[GeoNode-devel] Geoserver: No AuthenticationProvider on GeoNode Container
Daniel Berry
dberry at boundlessgeo.com
Wed Jan 4 18:16:18 PST 2017
Wayner,
While in the geoserver container can you wget
http://{django_hostname_or_ip}/api/roles
and see a similar result as below?
{"groups": ["anonymous", "admin"]}
On Wed, Jan 4, 2017 at 7:39 PM, Wayner Barrios <wayner at piensa.co> wrote:
> Daniel,
> For sure, I did python python manage.py loaddata default_oauth_apps on
> Makefile and overwrote IPs on xmls files into geoserver container.
> On Wed, Jan 4, 2017 at 6:58 PM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
>> Wayner,
>> Did you ensure that you loaded the fixture?
>> In my docker setup I also needed to run some sed statements for the
>> security filter and role file for oauth2 in geoserver data dir,
>> specifically these -
>> sed -i.bak 's at localhost:\(8000\|8080\)@172.16.238.2 at g' \
>> /tmp/geoserver/data/security/
>> filter/geonode-oauth2/config.xml && \
>> sed -i.bak 's at localhost:8000 at 172.16.238.2@g' \
>> /tmp/geoserver/data/security/role/geonode\ REST\ role\
>> service/config.xml && \
>> I had run into an issue with GEONODE_LOCKDOWN = True
>> https://github.com/GeoNode/geonode/pull/2801
>> Cheers!
>> Dan
>> On Wed, Jan 4, 2017 at 2:12 PM, Wayner Barrios <wayner at piensa.co> wrote:
>>> Hi All,
>>> I've been trying deployment on docker with the new authentication on
>>> docker, and I got the following error.
>>> [image: Inline image 1]
>>> However, django container and geoserver container are connected in the
>>> same network, because I can ping it and curl it. As you can see in the
>>> following:
>>> root at db8cd2498945:/usr/src/app# ping geoserver
>>> PING geoserver (172.23.0.7): 56 data bytes
>>> 64 bytes from 172.23.0.7: icmp_seq=0 ttl=64 time=0.349 ms
>>> 64 bytes from 172.23.0.7: icmp_seq=1 ttl=64 time=0.194 ms
>>> 64 bytes from 172.23.0.7: icmp_seq=2 ttl=64 time=0.135 ms
>>> 64 bytes from 172.23.0.7: icmp_seq=3 ttl=64 time=0.210 ms
>>> 64 bytes from 172.23.0.7: icmp_seq=4 ttl=64 time=0.126 ms
>>> 64 bytes from 172.23.0.7: icmp_seq=5 ttl=64 time=0.163 ms
>>> 64 bytes from 172.23.0.7: icmp_seq=6 ttl=64 time=0.150 ms
>>> root at db8cd2498945:/usr/src/app# curl geoserver:8080
>>> <!DOCTYPE html>
>>> <html lang="en">
>>> <head>
>>> <meta charset="UTF-8" />
>>> <title>Apache Tomcat/9.0.0.M13</title>
>>> <link href="favicon.ico" rel="icon" type="image/x-icon" />
>>> <link href="favicon.ico" rel="shortcut icon" type="image/x-icon" />
>>> <link href="tomcat.css" rel="stylesheet" type="text/css" />
>>> </head>
>>> <body>
>>> <div id="wrapper">
>>> <div id="navigation" class="curved container">
>>> <span id="nav-home"><a href="http://tomcat.apache.org/">Home</a></span>......
>>> Does anyone give any solution or the best way to do that? I just followed those steps from GeoSolutions: GeoSolutions_new_GeoServer_setup.txt <https://github.com/GeoNode/geonode/files/685760/GeoSolutions_new_GeoServer_setup.txt>
>>> Who can give me support on that?
>>> Best,
>>> Wayner
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> *Daniel Berry*
>> Senior Software Engineer | Boundless
>> 512-468-3946 <(512)%20468-3946> (cell)
>> @boundlessgeo
*Daniel Berry*
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170104/42002a5c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170104/42002a5c/attachment-0001.png>
More information about the geonode-devel
