[GeoNode-devel] LockFailed: failed to create /var/www/...
John, Steffen
s.john at atenekom.eu
Thu Jan 26 01:39:53 PST 2017
Hi!
My issue is related to the following issue on github:
https://github.com/GeoNode/geonode/issues/2106
I'm using Geonode 4.2.1 on Ubuntu 14.04 in a virtual machine.
When saving a new map, the LockFailed-Error appers.
I added NOTIFICATION_LOCK_LOCATION='/var/www/geonode' to the settings as suggested in issue 2106 and made sure that ww-data has write access to /var/www/geonode.
But still i'm getting the error, since it still tries to create the lock at a wrong location.
LockFailed: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-1- 9171
I'm wondering why it doesn't take the correct location from the settings?
Any ideas to solve this issue?
Thanks in advance!
Steffen
PS: here is the full stacktrace:
Internal Server Error: /maps/new/data
File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112, in get_response
response = wrapped_callback(request, *callback_args, **callback_kwargs)
File "/usr/local/lib/python2.7/dist-packages/geonode/maps/views.py", line 416, in new_map_json
map_obj.save()
File "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line 90, in save
return super(PolymorphicModel, self).save(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in save
force_update=force_update, update_fields=update_fields)
File "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 582, in save_base
update_fields=update_fields, raw=raw, using=using)
File "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185, in send
response = receiver(signal=self, sender=sender, **named)
File "/usr/local/lib/python2.7/dist-packages/geonode/social/signals.py", line 165, in notification_post_save_resource
send_queued_notifications.delay()
File "/usr/lib/python2.7/dist-packages/celery/app/task.py", line 452, in delay
return self.apply_async(args, kwargs)
File "/usr/lib/python2.7/dist-packages/celery/app/task.py", line 546, in apply_async
link=link, link_error=link_error, **options)
File "/usr/lib/python2.7/dist-packages/celery/app/task.py", line 727, in apply
request=request, propagate=throw)
File "/usr/lib/python2.7/dist-packages/celery/app/trace.py", line 315, in eager_trace_task
uuid, args, kwargs, request)
File "/usr/lib/python2.7/dist-packages/celery/app/trace.py", line 218, in trace_task
R = retval = fun(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/geonode/tasks/email.py", line 22, in send_queued_notifications
send_all(settings.NOTIFICATION_LOCK_LOCATION)
File "/usr/lib/python2.7/dist-packages/notification/engine.py", line 43, in send_all
lock = acquire_lock(*args)
File "/usr/lib/python2.7/dist-packages/notification/engine.py", line 31, in acquire_lock
lock.acquire(LOCK_WAIT_TIMEOUT)
File "/usr/lib/python2.7/dist-packages/notification/lockfile.py", line 249, in acquire
raise LockFailed("failed to create %s" % self.unique_name)
LockFailed: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-1-9171
ERROR:django.request:Internal Server Error: /maps/new/data
map_obj.save()
[Thu Jan 26 03:07:51.940734 2017] [:error] [pid 9171:tid 139927198664448] LockFailed: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-1-9171
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170126/96d94dfe/attachment.html>
More information about the geonode-devel
