[GeoNode-devel] Printing doesn't work correctly when layer is filtered
Dimitris Karakostis
karakostis.dimitris at gmail.com
Mon Jun 12 01:50:27 PDT 2017
Hi all,
When I create a map with multiple layers (GeoNode 2.4) if I filter the data
of each layer using the "Layer with filters" functionality then these
layers are not printed and not appeared in the pdf output of mapfish.
What I get in geoserver is an error message:
"Layers and filters are mismatched, you need to provide one filter for each
layer"
Has anyone similar issues?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170612/8ef52a2e/attachment.html>
More information about the geonode-devel
