[GeoNode-devel] GeoServer basic authentication not working anymore?
Paolo Corti
pcorti at gmail.com
Mon Mar 6 08:41:11 PST 2017
Hi Alessio
I did not change anything in GeoServer, I am using the one that comes
with GeoNode.
If I create a superuser right now, using the Django administrative
interface, I cannot login to the GeoServer admin interface using the
credentials for this superuser.
Which I believe it should be possible, if basic auth would be in place, no?
I can use the default administrative GeoServer account though (the one
with credentials: admin, geoserver).
Same thing using owslib: I can't login with my new superuser, but I
can using the administrative account.
Thanks a lot
p
On Mon, Mar 6, 2017 at 11:17 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Hi Paolo,
> the basic auth works since otherwise it would not be possible to upload
> layers neither.
> Maybe the order of authentication providers is wrong on GeoServer or your
> user somehow has a different password and/or removed.
> Another possibility when accessing a layer could be that the security
> settings on GeoFence do not allow you to access the latter.
> If possible rise up the log level of GeoServer and see what happens on
> $GS_DATA_DIR/logs/geoserver.log
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, Mar 6, 2017 at 4:52 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Hi devs
>> I am testing the trunk version of GeoNode, and I need to run some
>> script on layers using basic authentication and owslib.
>> This was working well with the old GeoServer authentication system of
>> GeoNode (without GeoFence).
>> It should still working now as well, as I can see basic authentication
>> is the first authentication provider in the authentication providers
>> chain, followed by geofence and geonodeauthprovider.
>> Unfortunately basic authentication does not seem to work. I cannot
>> login in the GeoServer admin interface with my credentials, and if I
>> try to make requests using owslib and my credentials I get this error:
>> No AuthenticationProvider found for
>> org.springframework.security.authentication.UsernamePasswordAuthenticationToken
>> Any idea here? Thanks in advance
>> p
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel
