[GeoNode-devel] SSL error on upload and saving metadata
Jonathan Doig
j.doig at unsw.edu.au
Mon May 8 23:27:50 PDT 2017
Hi devs
I'm putting our Geonode 2.4 behind SSL to protect the passwords over the net.
Based on the doco<http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html> I've written two ansible scripts, one<https://github.com/UNSW-CFRC/geonode_install/blob/master/install_geonode/10_generate_ssl_csr.yml> to generate the key and CSR, the other<https://github.com/UNSW-CFRC/geonode_install/blob/master/install_ssl_cert.yml> to install the certificate supplied by our university IT. I included the step to add the certificate to httplib2/cacerts.txt for python.
This works OK in general - the site itself shows as secure in Chrome.
However, I get errors when uploading a layer and saving metadata:
SSLHandshakeError at /layers/geonode:test_issue086a/metadata
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)
Any thoughts?
This is similar but not identical to the issue reported last year by Antoine Rolland (below).
Regards
Jonathan
Jun 06, 2016; 11:20pm [Antoine ROLLAND] <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=user_nodes&user=379386> Antoine ROLLAND<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=user_nodes&user=379386> SSL HandshakeError
Hello everyone,
I'm using Geonode 2.4 stable version, and it's now running under SSL. After this change, part of the website is still working well, but I meet errors while editing metada (when I save), and also when I try to upload a new layer. This is the error I meet :
SSLHandshakeError at /layers/geonode:communes/metadata
[Errno 1] _ssl.c:510: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
Request Method: POST
Request URL: https://aware.cirad.fr/layers/geonode:communes/metadata
Django Version: 1.6.11
Exception Type: SSLHandshakeError
Exception Value:
Exception Location: /usr/lib/python2.7/dist-packages/httplib2/__init__.py in connect, line 1043
Python Executable: /usr/bin/python
Python Version: 2.7.6
Python Path:
['/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/pymodules/python2.7',
'/var/www']
Server time: lun, 6 Jui 2016 09:09:43 -0400
Also, it seems that the url of the website generated is wrong : a "/" is missing between "websitename" and "uploaded/thumbs" (for instance). I suppose it is a consequence of the error i meet.
Any help would be really appreciated
Thanks
Antoine Rolland
geonode-devel mailing list
[hidden email]<http://osgeo-org.1560.x6.nabble.com/user/SendEmail.jtp?type=node&node=5270129&i=0>
http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170509/b9f332ed/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170509/b9f332ed/attachment.png>
More information about the geonode-devel
