[GeoNode-devel] GeoNode UpdateLayers in Admin interface
Simone Dalmasso simone.dalmasso at gmail.com
Fri May 12 03:12:01 PDT 2017
Glad you solved,
not sure about what's the best way to do that, maybe not directly through
the admin but it can be a "fake" admin. A django view, password protected
that responds only to the url /admin/updatelayers.
This url should be one of the first in the url mappings.
But try to take a look at the django documentation anyway.
Best
2017-05-12 11:21 GMT+02:00 <Martino.BONI at ext.ec.europa.eu>:
> Dear Simone,
> thanks, it solved, there were some thumbnails, previously saved from an
> other user and it was not possible for Apache to overwrite them; deleted
> and now it is working.
> By the way my app now is working  through a specific url
> (<baseurl>/updatelayers), is it possible to include this management app
> under the admin interface (eg. <baseurl>/admin/updatelayers) ? can you
> give me some hints or documentation to work on this.
> Super thanks and regards,
> Martino.
> *From:* BONI Martino (JRC-ISPRA-EXT)
> *Sent:* 12 May 2017 10:21
> *To:* Simone Dalmasso
> *Cc:* geonode-devel at lists.osgeo.org
> *Subject:* RE: [GeoNode-devel] GeoNode UpdateLayers in Admin interface
> Hi Simone,
> thanks for your reply, I will check the folder and file permission and let
> you know if this fixes the issue.
> Thanks for your time.
> Martino.
> *From:* Simone Dalmasso [simone.dalmasso at gmail.com]
> *Sent:* 11 May 2017 21:16
> *To:* BONI Martino (JRC-ISPRA-EXT)
> *Subject:* Re: [GeoNode-devel] GeoNode UpdateLayers in Admin interface
> Hi this error, as it says, is a permission denied in writing the thumbnail
> to the disk. Make sure the uploaded folder has write permissions to the
> user launching the command.
> 2017-05-11 19:11 GMT+02:00 <Martino.BONI at ext.ec.europa.eu>:
>> Dear all,
>> is it possible to call the command
>> *python manage.py updatelayers*
>> from the admin interface of GeoNode?
>> I tried to make my own app and call the command through *call_command()* in
>> a view but I got the error reported below.
>> My skill with Django are quite poor.. does anyone have already add the
>> command to the admin interface?
>> I would like to update my layers to the Postgis store that I have already
>> set in geoserver and then publish the layer from geoserver, finally call
>> the command. I need to do the upload in this way due to the huge size of
>> some layers that I can not upload directly from geonode.. seems it goes in
>> timeout.. but maybe I'm wrong. Moreover I do not have access to the command
>> line of the production VM where the geonode is installed.
>> thanks in advance,
>> Martino.
>> Exception at /syncgeogeo/runsync
>> ('Failed to process SGDB_PTR', IOError(13, 'Permission denied'))
>> Request Method: GET
>> Request URL: ....
>> Django Version: 1.6.10
>> Exception Type: Exception
>> Exception Value:
>> Exception Location: /srv/www/geonode/geonode/base/models.py in
>> save_thumbnail, line 564
>> Python Executable: /usr/bin/python
>> Python Version: 2.7.5
>> Python Path:
>> ['/usr/lib/python2.7/site-packages/pip-6.1.1-py2.7.egg',
>>  '/srv/www/geonode',
>>  '/usr/lib64/python27.zip',
>>  '/usr/lib64/python2.7',
>>  '/usr/lib64/python2.7/plat-linux2',
>>  '/usr/lib64/python2.7/lib-tk',
>>  '/usr/lib64/python2.7/lib-old',
>>  '/usr/lib64/python2.7/lib-dynload',
>>  '/usr/lib64/python2.7/site-packages',
>>  '/usr/lib64/python2.7/site-packages/gtk-2.0',
>>  '/usr/lib/python2.7/site-packages',
>>  '/usr/share/httpd']
>> Server time: Thu, 11 May 2017 18:47:12 +0200
>> geonode-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170512/a23c0ab2/attachment-0001.html>
More information about the geonode-devel mailing list
