[GeoNode-devel] geonode 2.7.x vs master branch
Jeffrey Johnson
ortelius at gmail.com
Fri May 12 07:22:48 PDT 2017
+1
On Fri, May 12, 2017 at 6:09 AM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> +1
> ..Tom
> Sent from my iPhone
> On May 12, 2017, at 08:51, Patrick Dufour <pjdufour.dev at gmail.com> wrote:
> +1
> On May 12, 2017 8:02 AM, "Francesco Bartoli" <xbartolone at gmail.com> wrote:
> +1
> Sent from Nylas Mail
> <https://n1.nylas.com/link/22b7a3817e51c6be906fe615823bec11185dc5e1c42f1ed89e9e30eeca0b540b/0?redirect=https%3A%2F%2Fnylas.com%3Fref%3Dn1&recipient=geonode-devel%40lists.osgeo.org>,
> the best free email app for work
> On mag 12 2017, at 1:58 pm, Alessio Fabiani <alessio.fabiani at geo-solutions
> .it> wrote:
>> Please vote on renaming branches.
>> +1
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V
>> <http://goo.gl/it488V?recipient=geonode-devel%40lists.osgeo.org> for
>> more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> github
>> <https://github.com/afabiani?tab=overview&recipient=geonode-devel%40lists.osgeo.org>
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>> mob: +39 331 6233686 <(331)%20623-3686>
>> http://www.geo-solutions.it
>> <http://www.geo-solutions.it/?recipient=geonode-devel%40lists.osgeo.org>
>> http://twitter.com/geosolutions_it
>> <http://twitter.com/geosolutions_it?recipient=geonode-devel%40lists.osgeo.org>
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, May 12, 2017 at 12:49 PM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>> Yes, this solution works very good either.
>> In the meantime I will make sure to back port all changes on master to
>> 2.7.x.
>> So how to proceed? Move master to notification and promote 2.7.x to
>> master?
>> Best Regards,
>> Alessio Fabiani.
>> more information.
>> @alfa7691
>> github
>> GeoSolutions S.A.S.
>> Italy
>> On Fri, May 12, 2017 at 12:30 PM, Francesco Bartoli <xbartolone at gmail.com
>> > wrote:
>> +1
>> <https://n1.nylas.com/link/55f94dd2d6b73a40186117d0333ad42e4667a7e9aefb71283e745dec383ded36/0?redirect=https%3A%2F%2Fnylas.com%3Fref%3Dn1&%3Brecipient=geonode-devel%40lists.osgeo.org&recipient=geonode-devel%40lists.osgeo.org>,
>> On mag 12 2017, at 12:17 pm, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>> wrote:
>> Hi all,
>> Actually, as Simone noted, the unstable releases (2.5.x) happened from
>> master in the past, and I agree that this should keep happening.
>> Since the pubsub stuff is now fixed, what is holding us from having 2.7.x
>> merged back to master and deleted? The notification work? If yes, I propose
>> we rename current master to notification_branch (since it is already
>> linearly behind 2.7.4) and rename 2.7.x to master until the new
>> notification system can be optional.
>> Thoughts?
>> Angelos
>> On 05/12/2017 10:59 AM, Alessio Fabiani wrote:
>> Hi Simone,
>> yes I'm monitoring the situation. Currently I'm trying to keep master and
>> 2.7.x aligned as much as possible.
>> Now that the PUBSUB stuff has been fixed, after having tested it, my
>> propose is to return to normal situation.
>> Unless other comments I would proceed like this:
>> 1. Forward port 2.7.x improvements to master branch (now working)
>> 2. Let the 2.7.x become an aligned branch of master
>> 3. Move master to 2.8.x
>> Best Regards,
>> Alessio Fabiani.
>> Visit http://goo.gl/it488V <http://goo.gl/it488V?recipient=geonode-devel%40lists.osgeo.org> for more information.
>> @alfa7691
>> github <https://github.com/afabiani?tab=overview> <https://github.com/afabiani?tab=overview&%3Brecipient=geonode-devel%40lists.osgeo.org&recipient=geonode-devel%40lists.osgeo.org>
>> GeoSolutions S.A.S.
>> Italy
>> http://www.geo-solutions.it <http://www.geo-solutions.it/?recipient=geonode-devel%40lists.osgeo.org>http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it?recipient=geonode-devel%40lists.osgeo.org>
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> On Fri, May 12, 2017 at 9:49 AM, Simone Dalmasso <simone.dalmasso at gmail.com> <simone.dalmasso at gmail.com>
>> wrote:
>> Dears,
>> I noticed a lot of great contributions going on the repo lately, this is
>> great. I noticed that some of them are addressed to master and some on the
>> 2.7.x branch.
>> We used to use the numbered branches to freeze master just before the
>> release and do there only small fixes but most of the development is always
>> been on master.
>> I think we could end up in a very difficult to manage situation if we
>> split the commits between 2 as they will be soon very misaligned.
>> This is just a reminder :) before things get messy. There are for sure
>> reasons why lots of stuff is going to 2.7.x but just let's keep in mind to
>> keep 2.7.x and master aligned. Same applies to the small fixes on 2.6.x
>> that have to be ported on master, but that is easy.
>> Ciao!
>> Simone
>> geonode-devel mailing listgeonode-devel at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-devel <https://lists.osgeo.org/mailman/listinfo/geonode-devel?recipient=geonode-devel%40lists.osgeo.org>
>> Angelos Tzotsos, PhD
>> Charter Member
>> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos <http://users.ntua.gr/tzotsos?recipient=geonode-devel%40lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170512/66578abb/attachment-0001.html>
More information about the geonode-devel
