[GeoNode-devel] QGIS <-> GeoNode Integration
Francesco Bartoli xbartolone at gmail.com
Sun May 14 08:57:51 PDT 2017
Hi Tim,
thanks for the work, it is very huge!
Aside from the django API pattern which is the core of GeoNode I’d be very happy to add a more restful one to the api app, maybe with the power of django-rest-framework, at least for the business entities of GeoNode like layers, maps, documents.
Not sure this however can be of help for the integration.
Cheers,
Francesco
Il giorno 26/apr/2017, alle ore 17:20, Tim Sutton <tim at kartoza.com> ha scritto:
> Hi All
> I just wanted to show you some of the work we have been doing to integrate QGIS Desktop and GeoNode. I made a little video which illustrates it here:
> https://www.youtube.com/watch?v=z0WYsEUNmg4
> This work was funded by WorldBank  / GFDRR. We expect to make a pull request against QGIS to merge this work next week some time.
> There have been previous attempts to integrate GeoNode support into QGIS but ours is a bit different as it is implemented in C++ and will be 'native' / baked in code that every QGIS user can make use of without needing to install any plugins etc. We will also create python bindings for the helper classes so that you can use the GeoNode backend logic in your own QGIS plugins if you want to without re-inventing the wheel.
> My colleague, Gavin, has previously written to this list to provide a broad outline of our work plans. One of the pain points we have had while working on this functionality is the GeoNode API. Our implementation basically consisted of hopping around between the GeoNode API and GeoNode's CSW instance. This diagram summarizes the process we follow:
> https://files.gitter.im/kartoza/kartoza/ucRq/GeoNodeArchitecture.png
> We had to do a lot of hoop jumping to get valid layer end points and we would like to implement some changes to the API to make it less of a pain. Our first tentative doodling on how the API can be improved are here:
> https://files.gitter.im/kartoza/kartoza/YxLa/GeoNodeArchitecture-API.png
> We would make any changes as non breaking changes (unless people are using really crapping parsing techniques to pull data out of the API responses) - adding to some existing responses, and adding new API end points to support pushing and pulling styles and so on. I expect we will add more to the above diagram, consider it a first draft only. Is anyone else working on things that might affect the API / planning changes to the API? If so could we collaborate with you so that we can see what is coming down the line? Our work will probably be split between:
> a) a few specific changes we need to execute our work.
> b) a proposal of what other things might be improved in the API for future
> I look forward to hearing from anyone else who is interested in QGIS / GeoNode integration and GeoNode API improvements.
> Regards
> Tim
> <KartozaNewLogoThumbnail.jpg>
> Tim Sutton
> Co-founder: Kartoza
> Project chair: QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> Skype: timlinux
> IRC: timlinux on #qgis at freenode.net
> Kartoza is a merger between Linfiniti and Afrispatial
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170514/df8c83e7/attachment.html>
More information about the geonode-devel mailing list
