[GeoNode-devel] SSL error on upload and saving metadata
Jonathan Doig j.doig at unsw.edu.au
Tue May 30 15:30:24 PDT 2017
Hi all
Following this up with the solution for posterity.
Turns out I couldn’t get a signed certificate with the actual hostname included in the subjectAltName, as our signing authority doesn’t cover the actual host domain. Anyway that wasn’t the problem. The problem (thanks Vaughan!) was missing root and intermediate certificates.
The full solution was to:
  1.  Add our (QuoVadis) root and intermediate certificates to /etc/ssl/certs/geonode-chain.crt
  2.  Point to this file from  /etc/apache2/sites-available/geonode.conf by adding this line:
SSLCertificateChainFile /etc/ssl/certs/geonode-chain.crt
  1.  Add the root certificate to /usr/local/lib/python2.7/dist-packages/httplib2/cacerts.txt
  2.  In local_settings.py, set OGC_SERVER default LOCATION to https://fully.qualified.domain.name/geoserver
Words to this effect should probably be added to http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
I’ve added it to our own (tested) Ansible playbook at https://github.com/UNSW-CFRC/geonode_install/tree/master/roles/install_ssl
Regards
Jonathan
From: geonode-devel [mailto:geonode-devel-bounces at lists.osgeo.org] On Behalf Of Jonathan Doig
Sent: Wednesday, 10 May 2017 5:12 PM
To: Cezary Statkiewicz <cezary.statkiewicz at geo-solutions.it>; geonode-devel at lists.osgeo.org
Subject: Re: [GeoNode-devel] SSL error on upload and saving metadata
Thanks for your response Cezary.
We have created an alias to our actual host. I think the problem might be that while the python running these functions is using https, it is still calling the actual hostname rather than the alias. It fails to verify the certificate because the hostname doesn't match the alias. So I’ve requested new certificates based on a config in which I’ve added the actual hostname to subjectAltName. I’ll let you know how it goes.
Curl output shows no problem with <my-alias>:
curl -vvv https://<my-alias>/geoserver/<https://%3cmy-alias%3e/geoserver/>
*   Trying <my-host-IP>...
* Connected to <my-alias> (<my-host-IP>) port 443 (#0)
* found 173 certificates in /etc/ssl/certs/ca-certificates.crt
* found 697 certificates in /etc/ssl/certs
* ALPN, offering http/1.1
* SSL connection using TLS1.2 / ECDHE_RSA_AES_128_GCM_SHA256
*        server certificate verification OK
*        server certificate status verification SKIPPED
*        common name: <my-alias> (matched)
*        server certificate expiration date OK
*        server certificate activation date OK
*        certificate public key: RSA
*        certificate version: #3
*        subject: C=AU,ST=New South Wales,L=Kensington,O=University of New South Wales,OU=City Futures Research Centre,CN=<my-alias>
*        start date: Mon, 08 May 2017 01:05:25 GMT
*        expire date: Fri, 08 May 2020 01:05:21 GMT
*        issuer: C=BM,O=QuoVadis Limited,CN=QuoVadis Global SSL ICA G2
*        compression: NULL
* ALPN, server accepted to use http/1.1
> GET /geoserver/ HTTP/1.1
> Host: <my-alias>
> User-Agent: curl/7.47.0
> Accept: */*
< HTTP/1.1 302 Found
< Date: Tue, 09 May 2017 23:48:37 GMT
< Server: Apache-Coyote/1.1
< Location: /geoserver/index.html
< Content-Length: 0
< Set-Cookie: JSESSIONID=5797370732D26CAD77DC9ABB69E89DC7; Path=/geoserver/; HttpOnly
* Connection #0 to host <my-alias> left intact
But it fails on <my-actual-host>:
curl -vvv https://<my-actual-host>/geoserver/<https://%3cmy-actual-host%3e/geoserver/>
*   Trying <my-host-ip>...
* Connected to <my-actual-host> (<my-host-ip>) port 443 (#0)
* SSL: certificate subject name (<my-alias>) does not match target host name '<my-actual-host>'
* Closing connection 0
curl: (51) SSL: certificate subject name (<my-alias>) does not match target host name '<my-actual-host>'
-----Original Message-----
From: geonode-devel [mailto:geonode-devel-bounces at lists.osgeo.org] On Behalf Of Cezary Statkiewicz
Sent: Tuesday, 9 May 2017 5:27 PM
To: geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
On Tuesday, May 9, 2017 8:27:50 AM CEST Jonathan Doig wrote:
> Hi devs
> I'm putting our Geonode 2.4 behind SSL to protect the passwords over
> the net.
> Based on the
> doco<http://docs.geonode.org/en/master/tutorials/advanced/geonode_prod
> uctio n/ssl.html> I've written two ansible scripts,
> one<https://github.com/UNSW-CFRC/geonode_install/blob/master/install_g
> eonod e/10_generate_ssl_csr.yml> to generate the key and CSR, the
> other<https://github.com/UNSW-CFRC/geonode_install/blob/master/install
> _ssl_ cert.yml> to install the certificate supplied by our university
> IT. I included the step to add the certificate to httplib2/cacerts.txt
> for python.
> This works OK in general - the site itself shows as secure in Chrome.
> However, I get errors when uploading a layer and saving metadata:
> SSLHandshakeError at /layers/geonode:test_issue086a/metadata
> [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed
> (_ssl.c:590)
Could you run
curl -vvv https://your.private.geoserver/geoserver/
curl -vvv https://your.public.geoserver/geoserver/
and put outputs from those commands?
> Any thoughts?
> This is similar but not identical to the issue reported last year by
> Antoine Rolland (below).
> Regards
> Jonathan
> Jun 06, 2016; 11:20pm [Antoine ROLLAND]
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=us
> er_no
> des&user=379386>  Antoine
> ROLLAND<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?m
> acro= user_nodes&user=379386> SSL HandshakeError Hello everyone,
> I'm using Geonode 2.4 stable version, and it's now running under SSL.
> After this change, part of the website is still working well, but I
> meet errors while editing metada (when I save), and also when I try to
> upload a new layer. This is the error I meet :
> SSLHandshakeError at /layers/geonode:communes/metadata [Errno 1]
> _ssl.c:510: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown
> protocol Request Method: POST Request URL:
> https://aware.cirad.fr/layers/geonode:communes/metadata
> Django Version: 1.6.11
> Exception Type: SSLHandshakeError
> Exception Value:
> [Errno 1] _ssl.c:510: error:140770FC:SSL
> routines:SSL23_GET_SERVER_HELLO:unknown protocol Exception Location:
> /usr/lib/python2.7/dist-packages/httplib2/__init__.py in connect, line
> 1043 Python Executable: /usr/bin/python Python Version: 2.7.6 Python
> Path:
> ['/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PILcompat',
>  '/usr/lib/pymodules/python2.7',
>  '/var/www']
> Server time: lun, 6 Jui 2016 09:09:43 -0400
> Also, it seems that the url of the website generated is wrong : a "/"
> is missing between "websitename" and "uploaded/thumbs" (for instance).
> I suppose it is a consequence of the error i meet.
> Any help would be really appreciated
> Thanks
> Antoine Rolland
> geonode-devel mailing list
> [hidden
> email]<http://osgeo-org.1560.x6.nabble.com/user/SendEmail.jtp?type=nod
> e&nod e=5270129&i=0>
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Cezary Statkiewicz
mailto: cezio at thelirium.net<mailto:cezio at thelirium.net>
xmpp: cezio at jabber.org<mailto:cezio at jabber.org>
pgp: https://thelirium.net/cezio@thelirium.net.pub.key
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170530/908c3c86/attachment-0001.html>
More information about the geonode-devel mailing list
