[GeoNode-devel] [Geoserver-devel] GeoGig Exception with GeoServer 2.12+
Erik Merkle emerkle at boundlessgeo.com
Tue Oct 17 13:49:10 PDT 2017
Alessio,
I just merged what "should" fix the issue. I wasn't able to reproduce it
locally. I assume there needs to be some other REST interaction outside of
GeoGig calls.
The PRs are merged here:
master - https://github.com/geoserver/geoserver/pull/2603
2.12.x - https://github.com/geoserver/geoserver/pull/26034
​The fix should at least prevent the NPE, and generate a debug log that
might give more information if it doesn't work as expected.​
​Thanks again for your patience,
Erik Merkle
Software Engineer | Boundless <http://boundlessgeo.com/>
<http://d32wfbeasdaw38.cloudfront.net/img/Boundless_Logo.png>
On Tue, Oct 17, 2017 at 10:27 AM, Erik Merkle <emerkle at boundlessgeo.com>
wrote:
> Thanks Alessio. I'll get a fix out ASAP
> Erik Merkle
> On Tue, Oct 17, 2017 at 10:26 AM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Hi Erik,
>> sure and thanks for your time.
>> Currently this is happening when running the war compiled with this
>> modules
>> https://github.com/GeoNode/geoserver-geonode-ext
>> http://build.geonode.org/geoserver/latest/geoserver-2.12.x.war
>> http://build.geonode.org/geoserver/latest/data-2.12.x.zip
>> Is it possible that could be an issue when including the monitoring
>> plugin also?
>> P.S.: in order to start that WAR you have to provide "GEOSERVER_DATA_DIR"
>> and "geofence.dir" JVM OPTS
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Oct 17, 2017 at 5:21 PM, Erik Merkle <emerkle at boundlessgeo.com>
>> wrote:
>>> Alessio,
>>> Can you give me any more details about your environment/setup when you
>>> see this? I can't reproduce it with the community GeoServer 2.12-beta and
>>> the plugin. I think I can fix it, but I'd like to be able to reproduce it
>>> to be sure.
>>> Many thanks again,
>>> Erik Merkle
>>> On Tue, Oct 17, 2017 at 9:36 AM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi Erik,
>>>> unfortunately is still doesn't work fine
>>>> Stacktrace here:
>>>> https://bpaste.net/show/09e2f5b6c0d8
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> On Tue, Oct 17, 2017 at 9:44 AM, Alessio Fabiani <
>>>>> Thanks Erik,
>>>>> will make a test asap.
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>> On Tue, Oct 17, 2017 at 12:54 AM, Erik Merkle <
>>>>> emerkle at boundlessgeo.com> wrote:
>>>>>> Alessio,
>>>>>> Thanks for letting me know. I hadn't come across this in testing
>>>>>> myself, but theses 2 merged PRs should address the issue:
>>>>>> (master) - https://github.com/geoserver/geoserver/pull/2600
>>>>>> (2.12.x) - https://github.com/geoserver/geoserver/pull/2601
>>>>>> ​Let me know if you still have issues with the plugin for GeoGig,
>>>>>> Erik Merkle
>>>>>> On Fri, Oct 13, 2017 at 12:16 PM, Alessio Fabiani <
>>>>>>> Sorry for cross-posting.
>>>>>>> Just wanted to highlight that currently trying to use GeoGig
>>>>>>> extension on GeoServer 2.12+ throws the following exception
>>>>>>> 13 ott 19:13:16 ERROR [geoserver.rest] -
>>>>>>> java.lang.NullPointerException
>>>>>>> at org.geogig.geoserver.spring.config.AbstractDelegatingGeogigM
>>>>>>> essageConverter.isGeogigPackage(AbstractDelegatingGeogigMess
>>>>>>> ageConverter.java:34)
>>>>>>> essageConverter.canWrite(AbstractDelegatingGeogigMessageConv
>>>>>>> erter.java:50)
>>>>>>> at org.springframework.web.servlet.mvc.method.annotation.Abstra
>>>>>>> ctMessageConverterMethodProcessor.getProducibleMediaTypes(Ab
>>>>>>> stractMessageConverterMethodProcessor.java:317)
>>>>>>> ctMessageConverterMethodProcessor.writeWithMessageConverters
>>>>>>> (AbstractMessageConverterMethodProcessor.java:184)
>>>>>>> at org.springframework.web.servlet.mvc.method.annotation.Reques
>>>>>>> tResponseBodyMethodProcessor.handleReturnValue(RequestRespon
>>>>>>> seBodyMethodProcessor.java:174)
>>>>>>> at org.springframework.web.method.support.HandlerMethodReturnVa
>>>>>>> lueHandlerComposite.handleReturnValue(HandlerMethodReturnVal
>>>>>>> ueHandlerComposite.java:81)
>>>>>>> at org.springframework.web.servlet.mvc.method.annotation.Servle
>>>>>>> tInvocableHandlerMethod.invokeAndHandle(ServletInvocableHand
>>>>>>> lerMethod.java:132)
>>>>>>> tMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHan
>>>>>>> dlerAdapter.java:827)
>>>>>>> tMappingHandlerAdapter.handleInternal(RequestMappingHandlerA
>>>>>>> dapter.java:738)
>>>>>>> at org.springframework.web.servlet.mvc.method.AbstractHandlerMe
>>>>>>> thodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
>>>>>>> at org.springframework.web.servlet.DispatcherServlet.doDispatch
>>>>>>> (DispatcherServlet.java:963)
>>>>>>> at org.springframework.web.servlet.DispatcherServlet.doService(
>>>>>>> DispatcherServlet.java:897)
>>>>>>> at org.springframework.web.servlet.FrameworkServlet.processRequ
>>>>>>> est(FrameworkServlet.java:970)
>>>>>>> at org.springframework.web.servlet.FrameworkServlet.doPut(Frame
>>>>>>> workServlet.java:883)
>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
>>>>>>> at org.springframework.web.servlet.FrameworkServlet.service(Fra
>>>>>>> meworkServlet.java:846)
>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
>>>>>>> at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder
>>>>>>> .java:808)
>>>>>>> at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilte
>>>>>>> r(ServletHandler.java:1669)
>>>>>>> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(Thr
>>>>>>> eadLocalsCleanupFilter.java:28)
>>>>>>> r(ServletHandler.java:1652)
>>>>>>> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(
>>>>>>> SpringDelegatingFilter.java:75)
>>>>>>> at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpB
>>>>>>> lacklistFilter.java:94)
>>>>>>> SpringDelegatingFilter.java:71)
>>>>>>> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.j
>>>>>>> ava:144)
>>>>>>> at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFi
>>>>>>> lter.java:71)
>>>>>>> at org.geoserver.filters.SpringDelegatingFilter.doFilter(Spring
>>>>>>> DelegatingFilter.java:46)
>>>>>>> at org.geoserver.platform.AdvancedDispatchFilter.doFilter(Advan
>>>>>>> cedDispatchFilter.java:50)
>>>>>>> at org.springframework.security.web.FilterChainProxy$VirtualFil
>>>>>>> terChain.doFilter(FilterChainProxy.java:316)
>>>>>>> at org.geoserver.security.filter.GeoServerCompositeFilter$Neste
>>>>>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>>>> at org.springframework.security.web.access.intercept.FilterSecu
>>>>>>> rityInterceptor.invoke(FilterSecurityInterceptor.java:126)
>>>>>>> rityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
>>>>>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>>>> at org.geoserver.security.filter.GeoServerCompositeFilter.doFil
>>>>>>> ter(GeoServerCompositeFilter.java:92)
>>>>>>> terChain.doFilter(FilterChainProxy.java:330)
>>>>>>> at org.springframework.security.web.access.ExceptionTranslation
>>>>>>> Filter.doFilter(ExceptionTranslationFilter.java:114)
>>>>>>> at org.geoserver.security.filter.GeoServerAnonymousAuthenticati
>>>>>>> onFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>>>>>> at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFi
>>>>>>> lter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
>>>>>>> at org.springframework.security.web.authentication.www.BasicAut
>>>>>>> henticationFilter.doFilterInternal(BasicAuthenticationFilter
>>>>>>> .java:213)
>>>>>>> at org.springframework.web.filter.OncePerRequestFilter.doFilter
>>>>>>> (OncePerRequestFilter.java:107)
>>>>>>> at org.geoserver.security.filter.GeoServerBasicAuthenticationFi
>>>>>>> lter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
>>>>>>> at org.springframework.security.web.context.SecurityContextPers
>>>>>>> istenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>>>>>>> at org.geoserver.security.filter.GeoServerSecurityContextPersis
>>>>>>> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFi
>>>>>>> lter.java:53)
>>>>>>> at org.springframework.security.web.FilterChainProxy.doFilterIn
>>>>>>> ternal(FilterChainProxy.java:213)
>>>>>>> at org.springframework.security.web.FilterChainProxy.doFilter(F
>>>>>>> ilterChainProxy.java:176)
>>>>>>> at org.geoserver.security.GeoServerSecurityFilterChainProxy.doF
>>>>>>> ilter(GeoServerSecurityFilterChainProxy.java:152)
>>>>>>> at org.springframework.web.filter.DelegatingFilterProxy.invokeD
>>>>>>> elegate(DelegatingFilterProxy.java:346)
>>>>>>> at org.springframework.web.filter.DelegatingFilterProxy.doFilte
>>>>>>> r(DelegatingFilterProxy.java:262)
>>>>>>> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.j
>>>>>>> ava:88)
>>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>>> at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDeb
>>>>>>> ugFilter.java:48)
>>>>>>> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilt
>>>>>>> er.java:44)
>>>>>>> at org.springframework.web.filter.CharacterEncodingFilter.doFil
>>>>>>> terInternal(CharacterEncodingFilter.java:197)
>>>>>>> at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHan
>>>>>>> dler.java:585)
>>>>>>> at org.eclipse.jetty.server.handler.ScopedHandler.handle(Scoped
>>>>>>> Handler.java:143)
>>>>>>> at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHa
>>>>>>> ndler.java:577)
>>>>>>> at org.eclipse.jetty.server.session.SessionHandler.doHandle(Ses
>>>>>>> sionHandler.java:223)
>>>>>>> at org.eclipse.jetty.server.handler.ContextHandler.doHandle(Con
>>>>>>> textHandler.java:1127)
>>>>>>> at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHand
>>>>>>> ler.java:515)
>>>>>>> at org.eclipse.jetty.server.session.SessionHandler.doScope(Sess
>>>>>>> ionHandler.java:185)
>>>>>>> at org.eclipse.jetty.server.handler.ContextHandler.doScope(Cont
>>>>>>> extHandler.java:1061)
>>>>>>> Handler.java:141)
>>>>>>> at org.eclipse.jetty.server.handler.HandlerWrapper.handle(Handl
>>>>>>> erWrapper.java:97)
>>>>>>> at org.eclipse.jetty.server.Server.handle(Server.java:499)
>>>>>>> at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
>>>>>>> at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConne
>>>>>>> ction.java:257)
>>>>>>> at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnec
>>>>>>> tion.java:540)
>>>>>>> at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(Queued
>>>>>>> ThreadPool.java:635)
>>>>>>> at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedT
>>>>>>> hreadPool.java:555)
>>>>>>> at java.lang.Thread.run(Unknown Source)
>>>>>>> Regards,
>>>>>>> Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> 55054  Massarosa
>>>>>>> (LU)
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> Check out the vibrant tech community on one of the world's most
>>>>>>> engaging tech sites, Slashdot.org! http://sdm.link/slashdot
>>>>>>> _______________________________________________
>>>>>>> Geoserver-devel mailing list
>>>>>>> Geoserver-devel at lists.sourceforge.net
>>>>>>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171017/f9f9b2df/attachment-0001.html>
More information about the geonode-devel mailing list
