[GeoNode-devel] GeoNode dependencies breaking & Pypi consistency
    Alessio Fabiani
    alessio.fabiani at geo-solutions.it
    Fri Oct 20 01:15:40 PDT 2017
+1
Already like this in GeoNode 2.7+
https://github.com/GeoNode/geonode/blob/master/requirements.txt
https://github.com/GeoNode/geonode/blob/master/setup.py
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Oct 20, 2017 at 12:50 AM, Jeremiah Cooper <
jcooper at jeremiahcooper.com> wrote:
> +1 to this.  MapStory has seen these breaking changes as well.  Pinning
> everything would help alleviate having to track down which dependency broke
> the build every time it happens.  It's happened several times just in the
> past few weeks.
> Thanks.
> Jeremiah Cooper
> On Thu, Oct 19, 2017 at 5:54 PM, Travis Brundage <
> tbrundage at boundlessgeo.com> wrote:
>> Hi all,
>> Recently I have seen some core GeoNode behaviour breaking due to changes
>> in our dependencies. This isn't the first time it's happened. What happens
>> is that we have many dependencies pulling in the latest version via >= in
>> our requirements, but something changes which conflicts with current
>> technology or otherwise is broken, causing core GeoNode to break as well.
>> In addition, I'd like for us to have consistency in regards to GeoNode
>> and its sub projects in pypi. Establishing the pypi repo as consistent with
>> the official repos for the dependencies will ensure changes are visible and
>> (hopefully) reviewed. This will help at least partially with preventing
>> broken dependencies. One possibility is introducing some automation here
>> through a continuous integration tool, so there are regular builds to pypi
>> straight off the repos in GeoNode. This method may help establish a
>> consistent cycle and also ensure we're diligent about quality in changes to
>> the code.
>> For the dependencies breaking, we can start pinning versions in our
>> requirements (that is, using == instead of >= in requirements.txt). The
>> upside of this is we will have consistent, expected behaviour that won't
>> change due to updates. The downside of this is we won't necessarily have
>> the most recent versions of dependencies, which we will want to
>> occasionally update. I feel pinning versions makes sense, but we should
>> make sure to update dependencies regularly. Before making this change, we
>> should check what versions are actually being used and working with
>> GeoNode, as >= will pull later versions, so simply doing a find+replace of
>> >= to == won't be correct.
>> Cheers,
>> Travis
>> Travis Brundage
>> Software Engineer | Boundless
>> 250.888.2820 <(250)%20888-2820>
>> @boundlessgeo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171020/5ad6f781/attachment-0001.html>
More information about the geonode-devel
