[GeoNode-devel] running tests conditionally
Simone Dalmasso simone.dalmasso at gmail.com
Tue Sep 5 07:13:29 PDT 2017
eh unfortunately our current tests will fail on postgres....
2017-09-05 16:06 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> Hi Simone
> I was considering to have the application installed by default. But
> yes, it makes sense to leave it out from INSTALLED_APPS (though I
> think most of us use PostgreSQL/PostGIS), and have the test running
> only it is there
> cheers
> p
> On Fri, Sep 1, 2017 at 3:50 AM, Simone Dalmasso
> <simone.dalmasso at gmail.com> wrote:
> > Ciao Paolo,
> > what about adding tests and specific settings for database in your
> contrib
> > app? When activating the app you will have to add it to the
> INSTALLED_APPS
> > and also add from geonode.contrib.yourapp.settings import *
> > This way the db will become postgres and the tests of the app will run.
> > We did something similar for contrib.mp
> > https://github.com/GeoNode/geonode/tree/master/geonode/contrib/mp
> > 2017-08-31 22:32 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> >> Hi devs
> >> I have a test module which needs to test a contrib application
> >> (createlayer, [1]) which requires PostgreSQL and an existing PostGIS
> >> database on the system.
> >> I am planning to have the test module for this contrib application
> >> called from paver only in the case that the conditions are met. Any
> >> good idea to implement this?
> >> thanks and cheers
> >> p
> >> [1] https://github.com/capooti/geonode/tree/create-layer-app
> >> Paolo Corti
> >> _______________________________________________
> >> geonode-devel mailing list
> >> geonode-devel at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > Simone
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170905/96115861/attachment.html>
More information about the geonode-devel mailing list
