[GeoNode-devel] Clarifications on GeoNode branches, version numbers and deb packages
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Sep 7 04:29:06 PDT 2017
Dears as I agree in principles with Angelos and Alessio who made this PR
https://github.com/GeoNode/geonode/pull/3270/files, I think that in
parallel we should also change pavement.py to handle the alpha, beta and
final tag better. With that PR, which respects our idea, I'm afraid that
ppl who don't know about our convention think that 2.9 is a final stable
release. Should we introduce the tag "unstable" for odd version instead? We
could remove the tag at all but then we loose the abiliti to do beta and rc
releases.
2017-09-07 11:17 GMT+02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> I think we could skip the ".alpha.0" part for ppa:geonode/unstable and
> just release 2.7.0 etc.
> Regards,
> Angelos
> On 09/07/2017 11:22 AM, Alessio Fabiani wrote:
> Dear all,
> after a talk with Simone Dalmasso, which clarified to me how GeoNode
> project manages versioning and branchning, I'm going to summarize here the
> current status on this topic on the next steps.
> - GeoNode odd version number are considered "unstable", which means they
> must be tested before promoted to a stable one. Therefore currently the
> 2.7.x is unstable and after the testing cycle it will be promoted to 2.8.x
> - GeoNode branch 2.7.x will contain versions which will be published to
> Launchapd and Pypi. Currently the version we need to release on
> "ppa:geonode/unstable" should be the "2.7.0.alpha.0"
> - GeoNode "master" branch should instead be bumped to 2.9dev version
> - After the testing cycle, once the 2.7.x will be considered stable, we
> will need to bump it to 2.8.0 and release on "ppa:geonode/testing" while in
> alpha and beta and "ppa:geonode/stable" when in rc and final state
> Did I miss something? Any other consideration or things to add?
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.ithttp://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing listgeonode-devel at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-devel
> Angelos Tzotsos, PhD
> Charter Member
> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/02574624/attachment.html>
More information about the geonode-devel
