[GeoNode-devel] PyCSW and GeoNode plugin
Tom Kralidis
tomkralidis at gmail.com
Wed Sep 27 10:18:28 PDT 2017
Hi Cezary: thanks for the info. We are long overdue for a pycsw 2.2.0
release. Once this is complete, then we can bump GeoNode pycsw dependencies
accordingly.
Having said this, I'll call for a pycsw Gitter meeting to address this
and other issues.
Thanks
..Tom
On Wed, 27 Sep 2017, cezary.statkiewicz at geo-solutions.it wrote:
> Date: Wed, 27 Sep 2017 16:47:37 +0200
> From: "cezary.statkiewicz at geo-solutions.it"
> <cezary.statkiewicz at geo-solutions.it>
> To: geonode-devel at lists.osgeo.org
> Subject: [GeoNode-devel] PyCSW and GeoNode plugin
> Hi,
> I've noticed that GeoNode repo plugin in master of pycsw has been removed, due to move of plugins to downstream projects [1][2]. However, corresponding issue in GeoNode [3] seems to be waiting. Could you tell what's the status of this?
> References:
> [1] https://github.com/geopython/pycsw/commit/877304b3336c56fe54acb2652556e8729b2c17e3#diff-4be29e3cb5df7aa60933b546605974f5
> [2] https://github.com/geopython/pycsw/pull/463
> [3] https://github.com/GeoNode/geonode/issues/2654
> Regards,
> Cezary Statkiewicz
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Cezary Statkiewicz
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
More information about the geonode-devel
