[GeoNode-devel] GeoNode monitoring
Cezary Statkiewicz
cezary.statkiewicz at geo-solutions.it
Fri Sep 29 04:53:59 PDT 2017
To: "cezary.statkiewicz at geo-solutions.it" cezary.statkiewicz at geo-solutions.it
Cc: "geonode-devel" geonode-devel at lists.osgeo.org
Date: Thu, 28 Sep 2017 16:08:09 -0400
Subject: Re: [GeoNode-devel] GeoNode monitoring
Hi Cezary
> it is a great work, thanks a lot!
> I am having a try, and I could successfully install and configure it. But
the console is not fed with monitoring data, and I see in the Django
log lot of lines (one every minute, as the default frequency) like
this:
> [28/Sep/2017 15:04:34] "GET
> /monitoring/api/metric_data/response.error.count/?last=undefined&interval=undefined
HTTP/1.1" 400 123
> Any idea?
> cheers
> ps I added some comment in your PR. Maybe I will add others once I can
make it working :)
Hi!
I'm glad you like it. As for those strange requests, it's frontend requesting for specific metric data. It should contain something else in last and intervals args though. Could you show your configuration? I've tested with known corner cases, but I couldn't reproduce.
You can get config with `manage.py collect_metrics -l`
Also, you should run `manage.py collect_metrics` from time to time (or add the call to crontab).
Regards,
Cezary Statkiewicz
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Cezary Statkiewicz
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
More information about the geonode-devel
