[GeoNode-devel] Geonode 2.8 in Vagrant
Corina Tudorache corina_ww at yahoo.com
Fri Apr 6 03:40:49 PDT 2018
Hi Pieter,
I also tried a Vagrant installation with Ubuntu 16.04 and private network, but running "sudo geonode updatelayers" throws an error:
Inspecting the available layers in GeoServer ...
GET http://localhost:8080/geoserver/rest/workspaces.xml
GET http://localhost:8080/geoserver/rest/workspaces/geonode/datastores.xml
GET http://localhost:8080/geoserver/rest/workspaces/geonode/coveragestores.xml
GET http://localhost:8080/geoserver/rest/workspaces/geonode/wmsstores.xml
GET http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/geonode_data/featuretypes.xml
GET http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/geonode_data/featuretypes/district_boundaries.xml
Found 1 layers, starting processing
Stopping process because --ignore-errors was not set and an error was found.
  File "/usr/bin/django-admin", line 9, in <module>
    load_entry_point('Django==1.8.19', 'console_scripts', 'django-admin')()
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
    utility.execute()
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line 394, in run_from_argv
    self.execute(*args, **cmd_options)
  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line 445, in execute
    output = self.handle(*args, **options)
  File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py", line 122, in handle
    execute_signals=True)
  File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 614, in gs_slurp
    "srid": resource.srid
Exception: ('Failed to process district_boundaries', AttributeError("'FeatureType' object has no attribute 'srid'",))
Does this command work for you?
Kind regards,
Corina
> On Apr 6, 2018, at 09:34, Alessio Fabiani <alessio.fabiani at geo-solutions.it> wrote:
> Hi guys,
> would you have some time to update documentation with this vagrant stuff?
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V <http://goo.gl/it488V> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it <http://www.geo-solutions.it/>
> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> 2018-04-06 10:02 GMT+02:00 Pieter du Plooy <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com>>:
> Hi Toni
> Thanks for all your help and guidance.  Geonode 2.8 is now running in vagrant perfectly, without having localhost exposed.  Private networking is such a clever way! I will probably be using vagrant with private networking more.  By the way, I have started to "vagrantize" geohelm (geohelm.org <http://geohelm.org/>) as a proof of concept using private networking.
> On a side note have you used Cartoview yet?  That is one project that I really want to use (as "extension" to Geonode), but have always been unable to do so, especially in vagrant or docker.  I think that might be a good project to install natively on Mac using your gist.
> Anyway, Thanks again.
> Pieter
> On Thu, Apr 5, 2018 at 12:17 PM, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Hey Pieter,
> yes Homebrew is installed here. But regarding geonode I did not any installation else except those
> mentioned in the gist. But I´ve installed qgis (http://www.kyngchaos.com/software/qgis <http://www.kyngchaos.com/software/qgis>)
> This installes some packages as well. Means If something is missing after you´ve run through
> the gist this could be the reason.
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1 <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> 04109 Leipzig <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> Mobil	+49/ (0) 176 6680 3198
> Tel 		+49/ (0) 341 24 04 738
> Fax 		+49/ (0) 341 24 04 73
> Web		http://csgis.de <http://csgis.de/>
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 05.04.2018 um 11:44 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com>>:
>> Hi Toni
>> Thanks for all the valuable info.  Last question though, did you install anything else like homebrew or macports packages for you Geonode OSX install"
>> Pieter
>> On Thu, Apr 5, 2018 at 9:35 AM, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
>> Hi Pieter,
>>> So what your saying is that if my router's address range is 192.168.1.xxx, I could tell vagrant that I want to use 192.168.1.33 (or whatever as last part), and thats that?
>> Exactly. After you´ve '$ vagrant up' have a look at virtualbox network setup. You will see a second network interface
>> further check /etc/network/interfaces on your vm. Vagrant did the „hard“ work for you. Of course you can change the ip
>> to your needs.
>> https://gist.github.com/t-book/e05e2b3905356e9a51fe7d6fa187ad4d <https://gist.github.com/t-book/e05e2b3905356e9a51fe7d6fa187ad4d>
>>> Any case, thanx so much for your help…
>> You´re welcome.
>>> I also saw that you are trying to get to run geonode on OSX, Any luck with that?
>> Yes this is how I did:
>>> By the way, a Geonode install from PPA, can I use ubuntugis-unstable as the repo for the gdal, and postgis stuff?
>> I have not tried yet but why? The package should install all which is needed?
>> Cheers,
>> Toni
>> CSGIS
>>> Am 05.04.2018 um 08:27 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com <mailto:pjduplooy.gis at gmail.com>>:
>>> Hi Toni
>>> Any case, thanx so much for your help...  O I also saw that you are trying to get to run geonode on OSX, Any luck with that?
>>> Regards.
>>> Pieter
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/geonode-devel <https://lists.osgeo.org/mailman/listinfo/geonode-devel>
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180406/ac71461b/attachment-0001.html>
More information about the geonode-devel mailing list
