[GeoNode-devel] Problem style's visualization
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 6 07:11:20 PDT 2018
Ok, we need to have more information about the error though. It's likely to
be a geonode misconfiguration for authentication but if you open the
browser console and try to open one of those failing requests in another
tab it should give you a file with the precise error.
2018-04-06 16:08 GMT+02:00 Openquake.org <armando at openquake.org>:
> Hi Simone,
> attached you pages of Geoserver and Geonode with the same project uploaded
> from qgis
> Armando
> On 06/04/2018 15:42, Simone Dalmasso wrote:
> Hi, which is the issue you are facing? Geoserver 2.9 doesn't have full
> compatibility with qgis generated SLD, but if you see it correctly in
> geoserver then it should to 100% the same in geonode
> 2018-04-06 11:07 GMT+02:00 Openquake.org <armando at openquake.org>:
>> Good Morning,
>> i have a problem with style's visualization when import the project from
>> qgis.
>> I use Geonode 2.6 and Geoserver 2.9-SNAPSHOT.
>> In Geoserver the style is perfectly but in Geonode the style's
>> visualization fails.
>> How could I solve this problem?
>> Thanks
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180406/a8cadc46/attachment.html>
More information about the geonode-devel mailing list
