[GeoNode-devel] ATTENTION: GeoNode GitHub Repos Summary and Status
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Apr 23 04:15:18 PDT 2018
Dear all, please read carefully here below.
You can find here the list and status of GeoNode GitHub current branched
updated @ 23rd April 2018
*2.8.0*
https://github.com/GeoNode/geonode/tree/2.8.0
- Based on Django 1.8.19 and Celery 4.1.0
- Compatible with Ubuntu 16.0.4 and CentOS 7 (the only ones officially
tested currently)
*NOTES:* This branch is frozen and contains everything until latest stable
GeoNode release 2.8.0. This branch won't be changed until the next release
for the 2.8.0 train (2.8.1).
At that point the source code of GeoNode 2.8.0 will be found only on 2.8 tag
https://github.com/GeoNode/geonode/releases/tag/2.8
*2.7.x*
https://github.com/GeoNode/geonode/tree/2.7.x
tested currently)
*NOTES:* This branch is the GeoNode 2.8.1 release candidate. Currently
marked as 2.7.7 version, before the official release process you will be
able to find 2.7.7+ deb packages on unstable ppa.
2.7.x train will remain based on Django 1.8 forever
*2.9.x/master*
- Based on Django 1.11.11 and Celery 4.1.0
- Still under testing. This is meant to be working with latest
Ubuntu/CentOS releases
*NOTES:* This branch is the GeoNode 2.10.0 candidate. Currently marked as
2.9.0 version, before the official release process you will be able to find
2.9.0+ deb packages on unstable ppa.
2.9.x train will remain based on Django 1.11 forever
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180423/d8dc6f47/attachment.html>
More information about the geonode-devel
