[GeoNode-devel] Deny upload for a group of users
Emídio Fernandes ebueno at spacesur.com
Thu Dec 13 06:00:30 PST 2018
Bravo Paolo grazie mille, i ll try
Best
El mié., 12 dic. 2018 a las 20:27, Paolo Corti (<pcorti at gmail.com>)
escribió:
> I think I remembered incorrectly this.
> After looking at the documentation of Django, it looks like you will
> need to decorate your view with @permission_required in order to check
> model permissions for the user.
> For example, to disable the upload page for a user which has not the
> layers.can_add permissions you should decorate this view (in
> layers.views):
> @login_required
> @permission_required('layers.add_layer', raise_exception=True)
> def layer_upload(request, template='upload/layer_upload.html'):
> I believe it would make sense to have these views permission required
> checks in GeoNode source code.
> Therefore a pull request would be welcomed.
> Paolo
> On Wed, Dec 12, 2018 at 6:08 PM Paolo Corti <pcorti at gmail.com> wrote:
> > Hello Emídio
> > you are right, I am not sure why this is happening but I don't think
> > is the expected behaviour from Django model permissions system, as far
> > as I remember. If a user or a group of user has not the permission to
> > create an instance of that model, Django should raise an error
> > automatically.
> > I am wondering if not using  the default value for
> > AUTHENTICATION_BACKENDS [1] for a Django project, but a combination of
> > different backends, including OAuth2, [2] change the things.
> > best
> > Paolo
> > [1]
> > AUTHENTICATION_BACKENDS = ['django.contrib.auth.backends.ModelBackend']
> > [2]
> > AUTHENTICATION_BACKENDS = (
> >     'oauth2_provider.backends.OAuth2Backend',
> >     'django.contrib.auth.backends.ModelBackend',
> >     'guardian.backends.ObjectPermissionBackend',
> >     'allauth.account.auth_backends.AuthenticationBackend',
> > On Wed, Dec 12, 2018 at 7:44 AM Emídio Fernandes <ebueno at spacesur.com>
> wrote:
> > > Grazie mille Paolo, i have tried to create groups as you said, but
> users from the group without permission to add/change/edit/delete layer
> still can upload  of data. Another thing i observed, after remove  the
> anonymous group its came appears again.
> > > Thanks
> > > El mar., 11 dic. 2018 a las 19:07, Paolo Corti (<pcorti at gmail.com>)
> escribió:
> > >> You should be able to accomplish this without forking GeoNode using
> > >> Django groups and customizing your templates. For example create 2
> > >> groups, one named "uploaders" and the other "not-uploaders". Make sure
> > >> the first group has the can add/change/edit/delete layer permissions
> > >> while the second not.
> > >> In your custom project templates hide links to the layer
> > >> administrative pages (layer upload, layer change metadata) when a user
> > >> belongs to the not-uploader group. As a last thing, add a signal in
> > >> your custom project to add each user to the not-uploader group when
> > >> she/he registers.
> > >> Hope this helps
> > >> Paolo
> > >> On Mon, Dec 10, 2018 at 2:58 PM Emídio Fernandes <ebueno at spacesur.com>
> wrote:
> > >> > hello everyone!!, i would like to know if it's possible deny a
> certain group of users to upload any data(vectorial, raster and document)
> to Geonode. Something like a viewer user
> > >> > tanks
> > >> > _______________________________________________
> > >> > geonode-devel mailing list
> > >> > geonode-devel at lists.osgeo.org
> > >> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > >> Paolo Corti
> > >> Geospatial software developer
> > >> web: http://www.paolocorti.net
> > >> twitter: @capooti
> > >> skype: capooti
> > > Emídio Bueno
> > > Geospatial Product Manager
> > > +54 (11) 4342-2976/84
> > > www.spacesur.com
> > Paolo Corti
> > twitter: @capooti
> > skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
*Emídio Bueno*
www.spacesur.com
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181213/f7a29095/attachment.html>
More information about the geonode-devel mailing list
